Results 1 to 15 of 15
Thread: Balancing from scratch - need to know order of chemicals
    Nov 2014
    Palm Desert, CA
    99
    Getting a reverse osmosis filtering for my pool water tomorrow (CH over 1000 now so it was time). After it's completed I will test and see how much of everything I need to start adding back in but I need to know in what order to adjust levels.
    Please let me know if I start with TA first, then FC, pool salt, etc..... I also need to know how much time I need to leave between additives.
    I have a SWG but am assuming I will need to use household bleach to begin with to get my FC up faster, I've never used bleach but I'm assuming it's just plain, ordinary, unscented stuff from the grocery store? Thanks all!
    17,000 gallon inground pool; Plaster redone January 2015; Pentair Cartridge Filter; SWG; Age of pool unknown (house built in 1973); Taylor K-2006 Test Kit.; Doheny Discovery robot cleaner.
    Jan 2012
    'burbs of Augusta, Georgia
    7,273
    Re: Balancing from scratch - need to know order of chemicals
    Quote Originally Posted by LisaDLu View Post
    Get your sock filled with granular CYA and ready to put in the water as soon as your treatment is done. You can hang it off a stick over a return or put it in your skimmer and make sure to run the pump until it is all dissolved. Squeese it now and then to speed things up. Or conversely if you've won the lottery recently and have bucks to spare you can buy liquid CYA.
    Test your water to see your levels: FC, CC, TA, CH.. don't bother with CYA as it won't be there yet. Then add as much liquid plain bleach as Pool Math tells you to match the amount of CYA you've aimed for. FC/CYA Chart. Until your SWG is back up and running, and maintaining your FC level, just keep using bleach daily to meet your needs.
    Keeping the SWG off, go ahead and start adding the appropriate amount of salt. Let it get brushed up and dissolved for 24 hours before you test it to see if its on target. You can start the SWG up when it is.
    15 minutes or so between adding chemicals is all that is necessary- gives you time to brush the pool to help mix everything up between doses, right?
    Test your water to determine what you need to add based on this: Pool School - Recommended Levels
    If you need further help just let us know
    38,251
    There is no definitive order in which things should be adjusted ... it depends on the test results.
    You know the CYA is going to be low, so that will need to be added.
    You are going to want to add FC right away (use plain bleach).
    Pool salt can be last since you can maintain the FC with bleach while balancing everything else with the SWG off.
    Nov 2014
    Palm Desert, CA
    99
    Reverse Osmosis complete. Took my CH from over 1000 to 200. Nice!
    Need a little more clarification to make sure I have this correct. Per testing I need to bring up FC, TA, CYA, and salt.
    I already have conditioner in a sock in the skimmer to bring up CYA (the amount per Pool Math) and will check the levels in a few days to see if I need more. My SWG is OFF.
    When do I start bringing up my TA, adding the salt and turn the SWG back on?
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    pH is always first. TA is last.
    I would wait to do an OCLT before adding salt and turning on SWG
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    38,251
    Test results?
    Apr 2013
    Philadelphia, PA
    20
    Quote Originally Posted by Mr Bruce View Post
    Wait what? Really? I thought you want to get TA first and the pH afterward. Shouldn't TA will help stabilize pH?
    25k Gallon, Wet Edge Prism Matrix Eclipse, DE, IG, Size pump and flow rate?!?!?
    Nov 2014
    Palm Desert, CA
    99
    Forgot to say I am also adding household bleach per the amount specified in Pool Math.
    Test results:
    FC - 0.76
    PH - 7.2
    TA - 46
    CYA - 17
    Salt - 900
    CH - 200 Yay!!
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,071
    How are you arriving at those numbers with a Taylor 2006 test kit?
    Nov 2014
    Palm Desert, CA
    99
    Those numbers are from the RO companys digital tester but mine are very similar:
    From my Taylor 2006 -
    FC - 0
    PH - 7.4
    TA - 50
    CYA - below 20
    Salt - not sure because SWG turned off
    CH - 225
    So I've added household bleach to the pool, have my conditioner in the sock. I will test FC again later today. Instead of adding more bleach can I use the 1" trichlor tablets in a floater to keep my FC stable? I have a whole bunch of them I never use because of my SWG. If FC stays stable can I go ahead and add the salt tomorrow and after salt dissolved turn on the SWG? I don't want to rush the process but I want to get the salt back in and the SWG turned on. Thanks!!
    38,251
    I would get the CYA to at least 30ppm quickly (I think you are doing this).
    And run an OCLT with the FC at least 10ppm to see if you need to SLAM before balancing for the SWG. After that, you could use the tablet if you want to slowly bring the CYA up.
    I would only increase the TA up to about 60ppm since keep it lower should slow the pH rise that occurs due to the SWG.
    Nov 2014
    Palm Desert, CA
    99
    Wow, it needs a lot of bleach! I put in 128 oz this morning and just put I another 121 oz. (FC is measuring at 1 now). Still have some conditioner being dissolved I the sock. I'm assuming I will be throwing in at least a few jugs of bleach a day while the CYA is rising? Is that correct? Thanks!
    38,251
    Correct, that is why the CYA needs to get up quickly.
    Nov 2014
    Palm Desert, CA
    99
    It's about 5pm. My FC is at 5 and my CYA is about 40. I just added more bleach to bring the FC up to about 10.
    I am going to do the OCLT test tonight. I will measure it at 8:30pm and again in the morning. Since I just added more bleach will leaving it 3.5 hours be enough so I can test at 8:30pm?
    If I lose no more than 1 ppm between my 8:30pm and the next morning reading I am safe to assume no algae and to start adding my pool salt? Let the pool salt dissolve for 24 hours then turn my SWG back on, correct? Thank you all.
    38,251
    3.5 hours is more than enough .. 30 minutes is usually enough.
    Correct on the rest
