Results 1 to 7 of 7
Thread: Stabilizer Question
    Sallie's Avatar
    May 2008
    Columbia, SC
    103
    Stabilizer Question
    I am in the process of adding stabilizer to my pool. It gets full sun most of the day, and I use bleach only. I've put it in the skimmer in some pantyhose. I read somewhere to check CYA level in 5 days. Here are my questions:
    (1) What level should I shoot for?
    (2) How soon can I backwash?
    (3) How often should I check CYA levels? I am adding water frequently because I'm losing water.
    (4) How much do you think it will take to take it from 0 to the proper level?
    (5) How soon can I check the level after adding stabilizer?
    BTW, I was very surprised at how quickly it dissolved.
    Sallie
    25 K gal., vinyl IG, Hayward 3/4 hp pump, Hayward Pro Series S-220T 18" sand filter, full sun all day, no main drain, Taylor K-2006C and K-1766 test kits, Circupool RJ45 SWG - Columbia, SC
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: Stabilizer Question
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by Sallie
    (1) What level should I shoot for? 30 to 50
    (2) How soon can I backwash? Waiting a week is best.
    (3) How often should I check CYA levels? Once you reach your target (I suggest 50 w/being in full sun), about once a month. I am adding water frequently because I'm losing water What's this about? Got a leak?
    (4) How much do you think it will take to take it from 0 to the proper level? I suggest you shoot for the lower of 30 for now and creep up on the 50. Using Jason's Pool Calculator (link in my sig), I get about 6 lbs to get to 30.
    (5) How soon can I check the level after adding stabilizer? You can check after about 48 hrs., but the full story may take about a week to appear in your testing.
    Welcome to the forum, neighbor
    You're done SLAMing when:
    Sallie's Avatar
    May 2008
    Columbia, SC
    103
    Yes, I have some kind of leak. I'm adding water about every other day. Got a new liner last year, but I know it could still be that. I did the dye test at the skimmer, the light and the returns, and nothing spectacular happened. I'm not getting any bubbles in the returns, as I have in the past when there was a problem. Can't really afford to get the leak detector people here, so I'm not sure what else we can check on our own.
    Sallie
    Sallie's Avatar
    May 2008
    Columbia, SC
    103
    Here's more about my leak. Today I looked at the filter, and there were two light streams of water coming down the filter from the black thing that holds the vari-flo valve. Sorry I don't know all of the correct terms. I do have a picture of this if someone wants to help. This leak is not always there, but I do see it occasionally. Hubby says it's as tight as he can make it. What causes this, and what can we do?
    I also checked the line that carries my backwash and waste water out. I can't see the end of the pipe because it's on the other side of a brick fence, and a tree is in the way; but the trench is on a slope. The higher part is dry, and there is water beginning where the pipe probably is and down the slope, so no doubt I am losing water that way. How do we fix that?
    I am determined to get my pool in order this year. In previous years, it has been hit and miss.
    Sallie
    It sounds like you might need a new spider gasket in your main valve. Posting the picture would help us be sure.
    Sallie's Avatar
    May 2008
    Columbia, SC
    103
    Tonight Hubby put in a new spider gasket. The old one had one spoke that was all but missing, and 3 of the others were all deformed looking. Thank you. Thank you. Thank you. I have been dealing with that leak last season, too, and just couldn't afford to get the leak people here. We've had them before, and they had to take up concrete and put in a new skimmer. I can't wait to check tomorrow to see how my waste line is doing. And besides that, I could never get my pool clear after they put in the new liner last year. Thanks to TFP, it's as clear as can be. I'm still learning, but I'm on my way!
    Sallie
