Thread: How to remove water from my pool? CYA too high
    May 2015
    Atlanta-GA-
    69
    Hi
    I have been using these stupid tablets from costco instead of bleach in my pool and was told here to stop as my CYA would climb. I just tested and indeed it did steadily week after week. It is now at 90 and should be at the highest at 50.
    What does this CYA do?
    Anyway I have an above the ground pool and pool calculator tells me I have to replace 44% of the water. That is some task!!! How do I do that?
    Thanks for the help
    Pat
    12' AG, 3200GA, cartridge filter, pool installed 6/20/2015, Taylor K-2006 test kit,
    38,237
    Re: How to remove water from my pool? CYA too high
    Have you discovered Pool School yet? Start with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    You have an AG pool ... easiest way to remove water is using a hose as a siphon.
    BTW, a CYA of 90ppm is workable if you always maintain enough FC and avoid algae.
    30,402
    Well, you have to drain some of your pool and refill. To get a better understanding of what we teach,
    please read ABC's of Pool Water Chemistry up in Pool School
    May 2015
    Atlanta-GA-
    69
    I have read the ABC of pool school thxs.
    My question was "How do I syphon"? Technique to use, I don't know how to syphon.
    Thxs
    Pat
    38,237
    Put a hose under the water, get all the air out (could use a return jet to shoot through the hose).
    Cover 1 end with your hand and take it out of the pool to below the water level.
    Remove your hand.
    Let physics take over
    May 2015
    Atlanta-GA-
    69
    Ok thanks for the syphoning technique, I will get to it.
    Pat
