Thread: Repair of Plaster
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Repair of Plaster
    I was installing some tiles on my waterline, and dropped some grout or thin set in the bottom of the pool, which hardened and when I hit with my brush I see a dark spot like the plaster came off and the gunnite is showing. Its about the size of a nickel... what to use to fix it, maybe EZ Patch #1 fs? any ideas. Thank you as always..The pool has been running just great thanks to this forumn.
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Re: Repair of Plaster
    well I removed the spot with a piece of PVC pipe and ma...strange...
    Autopilot SWG
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Sounds like the masonry stained the plaster and the acid removed it.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    yup, it looks like it, glad I fixed it.
    Autopilot SWG
