Thread: Aqua rite T-9, power light and led but no other lights
    Jun 2016
    Arundel, ME
    2
    My aqua rite T-9 is showing power but none of the other lights come on. The LED shows 4000. I tested salt and it is 3000. I tried scrolling through diagnostics but the display doesn't change when I hit the button. I tried switching off/auto/super but nothing changes. I powered down, waited a few minutes then powered up. No change. I don't even get the usual no flow light on start up. I'm not sure if it is generating because this problem just started.
    Re: Aqua rite T-9, power light and led but no other lights
    Resetting the display board might help.
    How To: Replace an AquaRite Display PCB - YouTube
    Turn off power.
    Remove cover plate
    remove display board (it just pulls off)
    Reinstall display board (line up holes with pins and plastic stands
    Reinstall cover plate
    Power up and check diagnostics
    Support the site
    Jun 2016
    Arundel, ME
    2
    It worked like a charm! Thank you so much. I love an easy fix.
    Support the site
