Results 1 to 15 of 15
Thread: No Ground or Bonding lugs on Heater
    Jun 2016
    Clarkson, KY
    7
    Balboa heater 5.5kw 50096 hot tub spa 240v 15 inch
    I bought this heater on Ebay. How do I ground this thing? There are two Lugs on the element, of course, and a pressure switch, but no lugs for ground or bonding. I want to run a dedicated 240V power to the heater (which also runs on 120V, according to the manufacturer). My pump is 120V plugged into a GFCI.
    Thanks in advance for someone's help.
    38,275
    Re: No Ground or Bonding lugs on Heater
    Welcome to TFP!!!
    Grounding and Bonding are 2 completely different things ... so which are you trying to do?
    Pictures of the heater might help ...
    That heater doesn't get bonded or grounded directly. There should be connections for the spa pack. Refer to the manual for proper wiring.
    Support the site
    Jun 2016
    Clarkson, KY
    7
    I thought I should bond it to the pump housing which is two feet away and ground it for obvious safety reasons. If only one of those is necessary, which one and how? Each will be connected to it's own power source.
    It is this heater:
    Server Error
    Jun 2016
    Clarkson, KY
    7
    This is an old tub my neighbor gave me..I re-plumbed it for leaks, and installed the 1 hp pump she gave me..I bought the in-line heater for a third the original price. There are no other metal parts on the tub. I plan to insulate and build an enclosure myself. It's simple, a seats four, 6 jets ...but I don't want to boil anyone.
    I mean fry anyone.
    Jun 2016
    Clarkson, KY
    7
    Maybe I should ask someone on my homebrew forum?
    38,275
    James already answered you
    Jun 2016
    Clarkson, KY
    7
    So, I can connect it to the load side of a gfci and It'll be safe?
    Apr 2013
    Sacramento, CA
    2,769
    Let's try this again, in part for the folks watching at home.
    You are totally rebuilding a portable spa and have purchased a balboa 5. 5 heater and want to know how to ground or bond it.
    The simple answer is you don't do either. The heater is connected to a "spa pac" which controls the spa. The spa pac is grounded back to the neutral buss bar of the main panel through the cord or hard wired conduit. So you need a spa pac.
    The heater (and spa pac for that matter) are sold as replacement parts for hot tubs sold as a complete piece of equipment. So these parts do not have bonding lugs. NEC 680.42 does not require bonding of these parts. However you structure if it's metal must be bonded to the ground.
    Yes it must be downstream of a GFCI. .
    Jun 2016
    Clarkson, KY
    7
    So, there's no way to use it and make it safe, without a 'spa pac'? Since my tub didn't have a spa pac. Just a couple air buttons on the top, I figure to stop and start the pump.
    Apr 2013
    Sacramento, CA
    2,769
    There's no way to make it operate. To control it without a spa pac.
    Apr 2013
    Sacramento, CA
    2,769
    I'm going to see a guy this morning who has been in the hot tub spa business for 40 years. I'll ask him this morning if it can be done without a spa pac.
    Jun 2016
    Clarkson, KY
    7
    Thank you very much. I'll check back this evening.
    Apr 2013
    Sacramento, CA
    2,769
    He says that in theory you could control it with a thermostat. But that's not the way it was designed.
    If you're going to freeform everything, get a master electrician to make sure it's safe.
    Support the site
