Results 1 to 7 of 7
Thread: Replacing liner fail
    undrpressure23's Avatar
    May 2014
    Newport News, Va
    98
    Hey TFP friends, made a huge mistake when replacing my liner and had the pool drained for too long. Any suggestion to get her back to life correctly, also some residual standing water did get past the liner when removing liner. Will this hurt the foundation? I will post pictures in the next post.
    Attachment 50045
    7540 Gallons, AG Pool, Hayward Sand Filter (Filter flow rate= 75 GPM), 3/4 HP Pump.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,535
    Re: Replacing liner fail
    Why do you say you let it stand without water too long? What damage do YOU see? Is the bottom flat still? It looks flat in the 1st picture. The second picture did not come through.
    I do see some rust you will want to clean up and spray paint.
    Give us some more details on what you are seeing that is causing your concern.
    Kim
    May 2014
    Newport News, Va
    98
    This is all done with lack of knowledge on my end, so I've had the water drained since december. There is a low spot on one side I would like to fix (from previous owner), sides have started caving in a little due to no water pushing out against the surrounding dirt. Also basically want to know if there are some things I should take of/or improve while I have the liner out?
    Jul 2012
    Tallahassee, FL
    30,535
    Work on the rust spots. If they are surface rust you can do a good sanding then spray paint with Rustoleum. If they are eating into the wall you will need to cut that spot out and replace it. There are several good threads due by others. Do a search in the search box at the top of the page.
    You can use clips and rope to help hold the sides up until you are ready to refill.
    Kim
    May 2014
    Newport News, Va
    98
    Thanks for your wisdom Kim, would now be a good time to add lights of this is the plan?
    Jul 2012
    Tallahassee, FL
    30,535
    Now WOULD be the time. Do NOT cut the liner until the water is right under the spot where the light will go due to stretching. They also make lights for above ground pools where you do not have to cut the liner. They hang over the wall.
    Pool Lights for Non-Niche Pools - INYOPools.com
    Kim
    May 2012
    Montville NJ
    545
    Is that pool partially buried? It looks like the one wall is bowed in near the bottom, but that could just be the picture, or the way the cove foam is laying. If that is the case, you will have to remove the dirt on the outside of the pool in that area. once you fill the pool, then you can put the fill dirt back. Make sure the wall is in the bottom track all the way around the pool.
    As for things you can add/improve - if you want to go with either a bottom pad or wall foam, then clearly now would be the time. I put wall foam on my pool, but I dont think it was worth it. It is a nice feel behind the liner, but I dont know if that is enough justification. Supposedly it helps insulate the pool too - I cant tell if it does or not.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
