Results 1 to 7 of 7
Thread: Dirty water pumped back in the pull at the start of the pump.
    Jun 2016
    North highlands ca
    4
    Hi!
    New pool owner and new to this forum. Looking for some advice. I have a unground pool with sand filter and Hayward valve. When I turn my pool pump on a lot of air comes out in the return line and after few seconds it goes away and then I get dirty water in the pool for a second. Why is that?
    30,431
    Re: Dirty water pumped back in the pull at the start of the pump.
    Welcome to the forum.
    When is the last time you backwashed and cleaned your filter?
    Jun 2016
    North highlands ca
    4
    I had it back washed Few days ago. It's been happening since I had a pool guy clear clogged inlet pipe.
    30,431
    What clogged it? Is it reclogged? "The first thing to fix is the last thing that broke"
    What is the psi on your filter? Did it read lower when you backwashed it?
    Jun 2016
    North highlands ca
    4
    Not much lower after back wash
    What clogged it was equaliptus leaves.
    Quote Originally Posted by Alavetis View Post
    Psi is just under 20
    Jun 2016
    North highlands ca
    4
    Any ideas, anyone?
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    483
    Any ideas, anyone?
    Really hard to say without more information. Like Dave said, I'd look at what the pool guy did. It could be a lot of things - from broken laterals in the sand filter to a bad spider gasket in the multivalve.
    SLAM * Chlorine/CYA Chart * Pool Math * Pool School
    17.5k gal IG Fiberglass, Triton II TR60 Sand Filter, Jacuzzi Magum Force Pump 1.5 hp, 3/4 hp booster, Polaris 280, TF-100 Test Kit with Speed Stir
