Thread: It's good to be here!
    May 2015
    Stamford, ct
    27
    Cool It's good to be here!
    Good morning everybody!
    I'm going into my 2nd season, but given my 80% horrible experience last year I'm considering myself an almost total noobie. However, thanks to discovering TFP end of last season, I've started on the right foot and started chlorinating with bleach over winter.
    My pool is a 4-5 years old, 20ft round, above ground vinyl, 10k, city water. 1.5 hp single speed pump Proline, Century A.O. Smith motor, with timer in the nearby garage. Sand filter. Bubble cover for speeding heating. New England.
    I'm committed to the TFPC method! I think it's already working since the water is clear. I like to learn so this is a nice experience -- as long as it's working .
    The Good: the pool is open and the water is bright and blue, wooho! It's a nice round vinyl pool with a deck around a quarter of it, in my backyard. Nice setup.
    The Bad: still too cold to to swim!
    The Ugly: most ugly is my equipment got damaged from the cold and absence of close when I bought the house in beginning of winter 2014 and the sellers failed to close it or explain what I should do. The pump got cracked from the cold and started leaking mid last season. Also my sand filter's lateral holder (the central piece) got cracked in 2 but it was neat, so we could re-glue it together and it's seemed fine since then (appeared last August after multiple backwashes), and I also changed the sand.
    The Tests:
    So far testing from strips and from Leslie's, but I've just placed an order for a TF-100 Test Kit with Speedstir Magnetic Stirrer
    As of last week -> yesterday:
    FC: 0 -> 2
    CC: 0 -> 0
    pH: 7.2 -> 7.7
    TA: 60 -> 70
    CH: 60 -> 70
    CYA: 0 -> 0
    Borates: not
    Temp: 68 -> 68
    FC fluctuates normally given there is no CYA and I'm adding some at least every 2 days. It goes down to zero under direct sun, and I add it in the evening.
    Some History:
    My pool was drained after the last close because of a leak at the bottom. So I started again with fresh water, no additives, just chlorine, and covered it in November. It was patched for a pleasant $75 by a local pool maintaining company. I kept on adding some chlorine throughout winter, as long as it wasn't frozen (this is the New England...). My cover got torn a bit so some debris got in but nothing major.
    Upon opening it it was still clear so after adding some more chlorine, I headed to Leslie for tests and supplies.
    I failed/forgot to backwash the filter.
    Last year, I had the common issue with too high CYA, so I didn't want to go with CYA at all, since I had fresh water, but reading this forum convinced me otherwise.
    I started to add 4 lbs of Alkalinity Up, but it didn't register that much in the test. I have 4 more I can add.
    After 4h, with pump running, I then added 1/2 gallon Instant Conditioner that I had from last year, to the skimmer and left the pump running 8h, and waited a week with the pump running twice a day for 3h each.
    Yesterday upon testing again, the CYA was still registering at 0 (both from strips and Leslie's).
    So I've now bought one gallon and have already added over 2 days, and am prepared to wait again. I've added it partially walking around the pool, and partly over the flow of the return into the pool.
    The pump situation: Since I inherited the pool from buying the house in winter, it wasn't closed properly and the pump's housing probably cracked from the cold. With my friend's help we tried to fix it with epoxy but it didn't hold for long. With my wife, we're going to try and salvage the housing using this technique found here: How to fix a cracked pump housing
    But I'm waiting for a few more days to keep the water circulating while the CYA registers in the tests. Just in case I'm left without a pump for a few days and I need to buy a new one and wait for delivery.
    Questions:
    1. Any idea why 1/2 gal of Instant Conditioner didn't register at all? Is it because I added it to the skimmer (following instructions on the bottle...) ? And maybe because I didn't backwash the filter before? Filter's pressure is constant at 12 psi since I started it.
    2. Any idea why the 4 lbs of Alkalinity up almost didn't register either?
    3. If the repair of the pump fails, any suggestions on a pump replacement? Should I go variable speed? How long should it run every day? I've found pumps from $119 to $400... it's a bit confusing and my goal this year is to not spend upwards of $2000 like I did last year (mostly on chems and new water).
    4. some greenish dots/pearls appear almost every day at the bottom and I vacuum them out. Is that algae?
    5. does a bubble cover protect FC against the UV's?
    6. I'm going to leave for a few weeks in 2 weeks. If the CYA has gone up to 25 as intended, will it be fine to leave the pool on automatic with some tablets for that long? I also don't want the CYA to go crazy with the tablets.
    Any suggestions on the general course of action are welcome but I think/hope I've got the general idea of the TFPC.
    Should I repost those questions on specific forums?
    Sorry for the super long post but I've processed a lot of the forums before posting and now I realize I have lots of questions!
    Thanks again for being here and for the welcome, cheers,
    Guillaume
    --Guillaume (pronounce: Ghi-Yom) - 10k vinyl above ground - 1.5hp single speed pump running 2x2h a day - 22in ClearWater sand filter - Liquid chlorine - Pool owner since 2015, in Stamford, CT - TF-100 kit
    Jun 2014
    15,059
    Re: It's good to be here!
    Hello "G" and welcome to TFP! I'll get right to your questions okay:
    No way of knowing until your TF-100 arrives. Once you get that test kit, post your own results and we'll have a better idea.
    Same as #1
    Your pool is fairly simple and not terribly large, so you could just stay with your current pump, but just replace the wet-end that has the crack.
    It's possible. We'll know more when your TF-100 arrives.
    Might depend on the type of cover. I would think a solid cover would work best for that.
    Yes, when your CYA is near the minimum level, you could use tabs to help maintain FC while not being too worried about CYA. But you have to calculate how much FC is expected to be gained each day by the use of tabs, so some liquid bleach additions may be required. The Pool math calculator can be helpful for that.
    Much of what will happen next is dependent upon your own TF-100 test results. Until then, simply add about 1/2 gallon of regular bleach to your pool each day until the kit arrives. I would not recommend taking any actions based on those pool store or test strip results. Hope this helps.
    May 2015
    Stamford, ct
    27
    Thanks Pat for the quick and thoughtful answer!
    1. 2. No way of knowing until your TF-100 arrives. Once you get that test kit, post your own results and we'll have a better idea.
    OK, agreed!
    ​crack.
    The pump housing (where the basket is) is cracked in the bottom, and replacing it would be $150+... That's why I wanted to try and repair it or change the whole pump. But I guess I can ask again after seeing how the repair goes. Seeing that a member did it, my wife and I want to try (she also doesn't want to spend if not needed!)
    Anyways thanks again and I'll be waiting for the TF-100!
    Cheers,
    Guillaume
    Casey's Avatar
    SW PA
    10,428
    Welcome to TFP! So glad you're here! I'm also happy to hear you purchased the TF100. It's a great kit! You'll love it!
    May 2015
    Stamford, ct
    27
    Pat, everyone,
    I've just received my TF-100 today, it's a great kit! I don't think I'm super comfortable with the CYA test though. We didn't really "pass" the 50 ppm standard test. We thought it was more like 30.
    Quote Originally Posted by Texas Splash View Post
    1. No way of knowing until your TF-100 arrives. Once you get that test kit, post your own results and we'll have a better idea.
    2. Same as #1
    3. Your pool is fairly simple and not terribly large, so you could just stay with your current pump, but just replace the wet-end that has the crack.
    4. It's possible. We'll know more when your TF-100 arrives.
    5. Might depend on the type of cover. I would think a solid cover would work best for that.
    6. Yes, when your CYA is near the minimum level, you could use tabs to help maintain FC while not being too worried about CYA. But you have to calculate how much FC is expected to be gained each day by the use of tabs, so some liquid bleach additions may be required. The Pool math calculator can be helpful for that.
    Here are my measures:
    FC: 4
    CC: 0.5
    pH: 7.5
    TA: 70
    CH: 100
    CYA: 30/40
    Borates: not
    Temp: 72 ?
    The water is very clear.
    I've been adding 1/2 gallon chlorine every day in the evening, except last night. Still, today there was free chlorine after a full day under the sun (actually, maybe 6h total because of trees), and the kids were in the pool for a couple of hours.
    The process is already so less painful this year than last.
    Back to my remaining initial questions:
    6. I'm going to leave for a few weeks in 1.5 weeks. If the CYA has gone up to 25 as intended, will it be fine to leave the pool on automatic with some tablets for that long? I also don't want the CYA to go crazy with the tablets.
    Guillaume
