Results 1 to 7 of 7
Thread: PH drop
    Mar 2015
    South Texas
    411
    PH drop
    I have always maintained my ph between 7.5 and 7.8. It tends to creep up and I usually have to add MA every month or two. My TA is rock solid at 70.
    After installing my SWG this week, I've been closely watching PH expecting it to rise quicker than usual, but to my surprise, just the opposite has happened. My PH has plumetted to 7.2 in just a few days. What am I missing?
    The only thing that I have done in the last week is added salt to 4000 ppm (I overshot a bit) and boric acid to bring my borate level back up form 30 to 50 ppm. (and added the SWG cell obviously). I also added CYA to bring my level from 50 to 80 ppm,
    DUH, just typing this out I answered my own question.
    I added 90 oz. of stabilizer which, according to poolmath, lowered my ph by 0.82.
    Now the question is should I leave it where it is and let it creep back up or should I add borax to bring it to 7.5?
    15,000 gallon free form Viking fiberglass pool. Hayward Star-Clear Plus C12002 cartridge filter. Hayward Swim Pure Plus T-15 SWG. Testing with TF-100 Kit. 2 speed 1.5HP Supreme pump. Dolphin Nautilus robotic cleaner
    Jul 2015
    Central Valley CA
    1,107
    Re: PH drop
    I would leave it. Save the borax for a serious over shoot, it will come up soon enought on it's own.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,255
    Re: PH drop
    I would leave the PH where it is and check daily to make sure it does not drop any lower. With aeration, over time, your PH will drift up. My PH drifted up every 4 days last year with a TA of 120. Now my TA is at 80 and it appears the PH increase is about every 8-10 days, but not 100% sure yet. On amazon, they have aeration devices that create tiny bubbles for a few $$$, or you could purchase the 360 degree rotating heads (which I have 4 of them), and this is what keeps my PH from staying stable. The positive side is that the water really circulates and I do not believe there are any dead spots. I have only brushed the pool maybe 3 times in 3 years and believe that it is not needed with 8 return jets (4 of them being oscillating).
    Here are the links:
    The Circulator Rotating Water Jets for Swimming Pools - YouTube
    Amazon.com : Circulator 10022a Automatic 360 Rotating Swimming Pool Cleaner Jet with Water Control Bottom Cap(2Pack) : Patio, Lawn Garden
    Amazon.com : Splash Pools 30700 Waterfall Pool Fountain : Swimming Pool Pump Accessories : Patio, Lawn Garden
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,993
    Re: PH drop
    Leave it.
    Here's the secret to a Troublefree pool: In poolmath, if your now readings are within the correct range, you enter them into the target column. Look! No chemicals needed! Micromanaging the numbers to reach some arbitrary target will just keep you constantly adding this and that, which is more like the pool store method than the Troublefree method.
    Mar 2015
    South Texas
    411
    Re: PH drop
    good call. Thanks everyone! I certainly have enough aeration when I want it. one big waterfall and two streamers to boot.
    Will leave it
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: PH drop
    Enjoy and have a cold one! TFP you've got it.
    Mar 2015
    South Texas
    411
    Re: PH drop
    Quote Originally Posted by bobodaclown View Post
    Thanks! I did!
