Results 1 to 8 of 8
Thread: CSI with SWG
    ahampleman's Avatar
    Nov 2011
    Ocala, FL
    30
    CSI with SWG
    HI all, so I installed the Cirupool RJ-45 last Saturday. CL has been stable @ 7PPM ever since. My ? come when looking at the CSI with all the #'s plugged in I have -.33. Test results below. What would you recommend I change to bring the CSI to about -.2? I have sat here for a couple of hours play with Poolmath and I'm at a loss.. even at a TA of 60 with Borate at 50 the PH is back at 7.8 after 2 days. When I installed the unit my TA was 80. I have no water feature that add additional PH rise.(other than the SWG)
    CL=7
    CC=0
    PH=7.6
    TA=60
    CH=500
    CYA=80
    Salt=3800 on k-1766 test, SWG= 3600
    Borate=50
    Temp=85
    Thank you,
    21,500 gallon outdoor in-ground 16'x32' Diamond Brite Cool Blue pool. Sta-Rite SuperMax 1.5 HP 2 speed pump running on low for 8 hrs a day, Sta-rite PCX125 cartridge filter, CircuPool RJ-45 SWG, 500 watt incandesce light, 1 skimmer, 4 returns, Dolphin Oasis Z5 robot cleaner, Solar-Breeze NX & TF-100 test kit, Taylor K1766 kit with speed stir.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: CSI with SWG
    Experiment a little. See how many days the pH will stay at 7.8. You might just discover that your pool is at equilibrium there and won't climb any higher for a week or ten days or even longer.
    Also remember that as water evaporates and is replaced, the CH will rise. That will push the CSI positive.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,737
    Re: CSI with SWG
    Maintain a higher pH to compensate for the borates and lower TA level. 7.8 will definitely balance things out a little better.
    ... And what Richard said more expeditiously
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    ahampleman's Avatar
    Nov 2011
    Ocala, FL
    30
    Re: CSI with SWG
    Thanks Richard and bdavis, The fill is already to the low point and need to bring it back up. I will try leaving the higher PH and see what happens. as the would bring the CSI to -.21.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: CSI with SWG
    First, why do you want to bring the CSI down to -2 (or is that a typo)? FWIW, PoolMath is showing me a CSI of -0.36 when I enter your parameters. In any event, it is above -0.6 which puts it within the recommended range. I would focus more on managing your individual parameters vs. worrying about CSI. Your parameters look good, although I wouldn't add any more borates. In fact, unless you have some other reason for using borates, I would let that drift down. If I remove the borates but leave the other parameters as-is, the CSI would increase (become more neutral vs. your current CSI) to -0.26.
    ahampleman's Avatar
    Nov 2011
    Ocala, FL
    30
    Re: CSI with SWG
    Quote Originally Posted by BoDarville View Post
    CSI corrected in #1 post. should be -.2
    It was my understanding that the CSI needed to between -.3 - .3.
    Thank you,
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: CSI with SWG
    Yeah, there are technically two thresholds for CSI - the hard ones at -0.6 or lower and 0.6 or higher along with two "warning track" thresholds at -0.3 and 0.3. If you were lower than -0.6 (or higher than 0.6), that would be more of a cause for concern. As the others suggested, try letting pH drift up to 7.8. The pH in my pool tends to hit equilibrium between 7.6 and 7.8 and rarely drifts up higher than that if I do nothing to adjust it.
    ahampleman's Avatar
    Nov 2011
    Ocala, FL
    30
    Re: CSI with SWG
    Thank again Bo. I'll see what happens over the next few days.
