Thread: Pump keeps tripping off after a few minutes
    Jun 2016
    Richmond
    1
    Hi , ive just install the summer waves above ground 16' 48' pool and the pump for whatever reason shuts down after a few minutes, im not sure if its not getting enough power thru my outlet I should also add im using a ( orange power extension cord ) from the pool to my inside outlet help please
    Jul 2015
    Central Valley CA
    1,107
    Re: Pump keeps tripping off after a few minutes
    Welcome to the forum!
    Couple of things to check for in no particular order. 1.) is the pump getting plenty of water and is the filter/return plumbing free of restriction. If you have a blockage somewhere the pump could be working harder than it should causing it to overheat and cut out. 2.) You could be correct about it not getting enough power do you have a larger gauge cord you can try and an outlet nearer the pump? 3.) You could have a bad GFCI on the pump that keeps tripping. There are been a few that have found the GFCI built into the cord to be less than reliable, assuming that is what you have. In those cases they have cut the GFCI off the pump and installed a normal 3 prong replacement. If you are going to try that make sure you plug the pump into a circuit that is GFCI protected even if it means you have to install a GFIC receptacle. They are $15 to $20 at most any hardware store and are an important safety feature to any electrical device that is near water.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Jun 2012
    western NY
    1,560
    when it shuts down, how does it restart? do you have to manually reset something such as a breaker or GFCI? As you know, or should know, powering a high current draw device such as a pool pump with an extension cord is not a good idea. Most orange extension cords are only good for about 10 amps of current flow. Te longer the cord gets, the higher the amp draw becomes due to the voltage drop. This voltage drop can cause motors to overheat. The best option for you is to have a proper outdoor receptacle installed near the pool pump following NEC 680 guidelines for pool electrical installations.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
