Thread: What type of glue to use?
    RonsPlc's Avatar
    May 2015
    Gaylesville, AL
    458
    I had posted a question here...
    Installing replacement liner inside of Intex 18' metal frame - Page 10
    Basically, I would like to know if regular PVC cleaner/glue would be the right choice to glue a patch of intex liner to another intex liner. From my research, it is actually a PVC that is used, instead of a straight up vinyl like regular pool liners?
    14600 gal Intex 24' Round 52" deep AG Pool (Heavily Modified)
    200lb sand filter w/2 speed 1.5/0.5hp pump
    Stenner 45MHP10 Liquid Chlorine (well... bleach) Injector. Borates added.
    K-2006 test kit w/Speedstir
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: What type of glue to use?
    Simplified explanation: The PVC cement used for chemically bonding PVC pipes has certain aggressive modifiers to "break through" the hard outer skin of the pipe, which is not present in PVC pool liners. These modifiers are likely to be too aggressive for a pool liner. Might be worth experimenting with, on something you don't care about destroying.
    Your best bet is to use a pool liner patch cement, like the Boxer brand from Union Labs. BTW, this is the cheapest I've found it....
    I like the idea you posted in the other thread about gluing a channel for a rope! I'll have to remember this when I replace my Intex liner next year.
    Jul 2014
    Oakbank, Canada
    389
    HH-66 glue works well too. Amazon.com: hh-66
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
