Thread: Chemical Question
    Apr 2014
    Upper Chichester, Pa
    60
    Chemical Question
    So we opened the pool and because they pump broke we ended up with algae. I have been shocking for 3 days and looks clear
    What should the borate be at? Also my Ph went up to 8.2 will this come down.
    here are my numbers this morning
    FC 14
    CC 1.5
    TA 50
    borate 15
    PH 8.2
    CYA 50
    Not sure if I should keep shocking or what to do since it is clear. Last testing yesterday the FC was 17
    Sharkline Reprieve 21' x 52" Round Above Ground Swimming Pool, Waterway 520-5220-6S ClearWater 19in. Sand Filter Above Ground Pool System with Hi-Flo Single Speed Pump, using BBB method and TF-100 kit
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Chemical Question
    because you are SLAMing the only numbers you should be checking are the FC and CC until you pass the OCLT.. with a CYA of 50 your SLAM level should be 20FC.. your PH will read high when your FC is above 10..
    with a CC of 1.5 you are still fighting algae, take your FC up to 20 and continue to test 3 to 10 times a day Your close
    Apr 2014
    60
    great thank you so much
    30,403
    Disregard the borates. Deal with them after your pool is clear.
