Thread: Pentair Intellichlor Output Percentage % Explanation
    May 2015
    Land O Lakes, FL
    527
    Just posting this for informational sake as I wanted to understand exactly how the % worked.
    Question: What is the on/off cycle time for the Intellichlor? For example, if set at 50%, does it cycle on for 1 min, then off for 1 min or 1 hr on/1hr off, etc. I would like to understand this for my own information and understanding the impact of the schedule.
    Answer:
    0% - No LEDs lit - No chlorine produced - IntelliChlor Electronic Chlorine Generator is off.
    20% - 1 LED lit - Produces chlorine 20% of each hour of pump run time, 12 minutes on, 48 minutes off.
    40% - 2 LEDs lit - Produces chlorine 40% of each hour of pump run time, 24 minutes on, 36 minutes off.
    60% - 3 LEDs lit - Produces chlorine 60% of each hour of pump run time, 36 minutes on, 24 minutes off.
    80% - 4 LEDs lit - Produces chlorine 80% of each hour of pump run time, 48 minutes on, 12 minutes off.
    100% - 5 LEDs lit - Produces chlorine almost 100% of each the hour of pump run time, 59 minutes on, 1 minute off.
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Pentair Intellichlor Output Percentage % Explanation
    Thanks, good info
    Jun 2015
    Dix Hills
    8
    Did you get this info from pentair? I have an IC 40 that I feel cant keep up with my pool and I actually measured the current draw from the power supply to see how long it runs. I only measured with it set at 100%. no other settings tested. The cell pulls 5 amps for 4 1/2 minutes were you can see bubbles from the jet then 0 amps for 5 1/2 minutes and no bubbles from jet.
    my thinking is that if 100% is 59 min on and 1 min off, isnt that the same as superchlorinate setting? whats the point of having the superchlorinate option?
    May 2015
    Land O Lakes, FL
    527
    Yes it came from pentair support. . I don't know how the super chlorinate function works.
    Matt
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    The super chlorinate is a 24 boost at 100% and then it reverts back to the original setting.
    The most likely cause of an SWG "not keeping up" is algae consuming the chlorine. Perform an Overnight Chlorine Loss Test to see if there is algae in the water.
    May 2015
    Land O Lakes, FL
    527
    Quote Originally Posted by pooldv View Post
    FYI, if the intellichlor is connected to an easy touch the super chlorinate is able to run for X X number of hours.
    Matt
