Results 1 to 9 of 9
Thread: Finally done construction!
    Lophat's Avatar
    Apr 2016
    Richmond, BC, Canada
    16
    It's been a long month but the pool is up and all the plumbing is complete. Since the plumbing took so long, the walls started to develop a slimy layer!
    Since I'm new to this, any advice is greatly appreciated! From what I've read, I should slam the pool after adjusting TA and Ph and scrub the walls and floor down. Check FC at night and recheck first thing in the morning to see if anything is using up the FC. No SWG during the slam and run the pump 24/7.
    Do I keep adding liquid chlorine in to bring it to shock levels each morning if it keeps dropping!
    once that is done, retest all parameters then add salt to recommended levels, fire up the SWG.
    add in borates and Muriatic acid.
    if I missed anything let me know.
    oh, first sample results are as follows:
    3 ppm FC
    0.2 ppm CC
    7.4 pH
    20 ppm TA
    20 ppm calcium hardness
    0 CYA
    40 ppm salt
    Atrium 12' x 23' AG Resin salt water pool w/ wall and ground insulation, 7300 gallons, Pentair Intelliflo VS pump, IC20 IECG, Clean and Clear 200 filter, Mastertemp 125 Gas heater and two Maytonics solar panels, Polaris AG pool cleaner. Easytouch 4, and Intellichem(undecided at this moment). All new Trex decking and patios to boot!
    May 2015
    Land O Lakes, FL
    527
    Re: Finally done construction!
    I am sure you are excited to finally get it done.
    You need to know how many gallons your pool is and put that in your signature. I am estimating around 7000 depending on your depth. You will use those gallons with http://www.troublefreepool.com/calc.html .
    1st, you should get some CYA. Sold as Stabalizer in granular or liquid form. The granular is cheaper and works the same. Here is a link to what it might look like. Lowes, HD or Walmart will have it. Put it in a old sock and hang it in front of a return. The amount you need will be determined in Pool School. Target 30 for now.
    Amazon.com : Clorox Pool Garden
    Then adjust to 7.2 pH and do the SLAM based on the CYA of 30. That would mean that the SLAM FC level would be 12.
    You will want to check FC frequently such as every few hours to ensure that it stays at at SLAM level as much as possibly until it passes the OCLT.
    Pool School - SLAM - Shock Level And Maintain
    Pool School - Perform the Overnight FC Loss Test (OCLT)
    Matt
    2016 Pool Build: 12k IG Blue Granite Pebblesheen, Travertine Coping & Pavers, Pentair IntelliFlo, Intellichlor, Easytouch, Clean & Clear 320, Heliocol Solar - TF-100 test kit w/ SpeedStir
    SWG Run Time Calculator
    Lophat's Avatar
    Apr 2016
    16
    Thank you for the great advice mgmoore7! Very much appreciated! When I go to the SLAM link, and it's associated sub links, it recommends CYA between 60-80 for salt pools. Should I still target 30? And is it because there is no salt added yet?
    triptyx's Avatar
    Apr 2016
    1,438
    Yes you still want to leave CYA at 30 for now. The 60-80 CYA level is for a healthy salt pool - raising your CYA to that level when you're going to SLAM anyways means you'll have to use a lot more bleach than if you leave it at 30.
    Once your SLAM is complete and the pool is sparkly, we can talk about adding salt and CYA to move towards getting the SWG started up.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    May 2015
    Land O Lakes, FL
    527
    Quote Originally Posted by triptyx View Post
    What he said.
    Matt
    Lophat's Avatar
    Apr 2016
    16
    Thanks fellas! So, with the first slam, the numbers are FC 3.2, CYA 35, ph 7.4, CC 0.2, TA 30 ppm, hardness (calcium)10 ppm, Nacl 100 ppm. I hope I'm doing this right. I added in 3 liters more of bleach and it is a bit high at 15.1. Added 750 grams of Borax as well to raise the ph. When should I add the salt?
    Jezza's Avatar
    Jan 2015
    Bunbury, WA, Australia
    883
    Hi Lophat,
    Just wondering if you are actually slamming or even needing to at this stage. Can't quite work out what your reason for SLAMming is? Did you conduct and pass the OCLT?
    11 000 gallons, IG, Fibreglass, Monarch Sand Filter, Davey Typhoon C100M 1HP pump, Davey Chloromatic Mc16CTO ESR SWG, Davey Pool Wall Climba Robot, Daisy Solar Cover,
    K-2006
    Lophat's Avatar
    Apr 2016
    16
    Hi Jezza,
    The water was sitting stagnant for a couple of weeks while we completed the plumbing. During which time, it grew a slimy layer on the walls below the pool surface. I left out that the first slam dropped from 13 ppm to 5 ppm overnight so I did it again last night. This morning the FC did not change (15ppm) so I think we're good now. The CC level was very low to begin with anyways. Maybe I'm being too paranoid.
    So my question now is if I can start to add salt and more Borax to get ready for opening day! (Father's day). I will still need to learn how to program the Easy touch but for now, manual switching of the pump is easy enough.
    thanks for all the guidance. I'll post pics soon!
    Jezza's Avatar
    Jan 2015
    883
    Ok so the water is clear and no evidence of the slimy layers on the walls right? Add the salt but just hold off on the borax for the moment. Give the salt 24 hours to fully dissolve before you fire up the SWG. You'll then eventually want to add stabiliser to get it up to the recommended 70-80 CYA for a SWG pool.
    I do have a slight reservation that if you had slimy walls that you have completed the SLAM so quickly -perhaps just go another OCLT to confirm.
    K-2006
