Thread: Chlorine overpowering alkalinity
    Jun 2014
    Newporr,ca
    42
    When doing a reading of alkalinity. I couldn't because my chlorine level was so high.
    Is there a way to read alkalinity when chlorine level is high?
    1500 gallons SPA. 104
    IG, Plaster, 6years old.
    Sand filter Triton ll TR140.
    Taylor K-2006 Complete Pool
    Pentair brominator feeder using bromine. Bi-carbonate. Calcium chloride.
    38,320
    Re: Chlorine overpowering alkalinity
    The TA test should work fine, although the color change might be different. See the extended test instructions in Pool School.
    Only the pH test does not read correctly at FC greater than 10ppm.
