Thread: Quick advice (doing tonight). Established a Bromide Reserve. Which will super shock?
    Jun 2014
    Houston, TX
    22
    I have Sodium Persulfate, Calcium Hypochlorite Mixture, Trichlor 3" tablets, Bromine 1" Tablets,
    I established a bromine reserve by using 4lbs of sodium bromide in my 8000 Gallon Hot Tub (Havent turned on heat until everythings balanced).
    Can I crush the bromine or trichlor tablets and use that to oxidize and supershock my water? Or can I use the powdered sodium/calcium hypo/persul in a few oz to do the same? Which is recommended?
    I have:
    • Sodium Persulfate
    • Calcium Hypochlorite hydrated
    • Trichlor* 3" Tablets (Triaz)
    • Bromine 1" Tablets (Bromochloro something)
    • 1 Gallon of Laundry Bleach ( Would prefer not to use this, but can)
    Levels:
    7.6 PH, 150 CH, 100 Alk, 2 Curent Bromine, 0 Copper and iron
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: Quick advice (doing tonight). Established a Bromide Reserve. Which will super sho
    I don't know much about bromine. This is the only article in Pool School that I know of that discusses sanitizing with bromine. Maybe it will help. How do I use Bromine in my spa (or pool)?
    Jun 2014
    Houston, TX
    22
    Quote Originally Posted by pooldv View Post
    Hi, scourged the net to find that and a few others.
    That's how I came up with my potential 'oxidizers'. Just wanted to see which one was recommended best without jacking any of my balanced levels too much (tried a bit of calcium but raided my pH from 7 to 10)
