Thread: Salt Levels
    Jun 2016
    Toms river NJ
    1
    Salt Levels
    I don't know if I am on the correct three but I am having a problem with my pool after converting to salt. My generator says one thing and every store I go to gives me different (Higher) salt reading than the other. This has been happening all week since converting even after lower the water level and refilling with fresh water. It's so frustrating.
    Help!!!
    38,275
    Re: Salt Levels
    My Hayward SWG has consistently from installation reported a salt level
    600-800ppm less than my Taylor test.
    As long as the SWG is happy, I just let it go.
    Jan 2012
    'burbs of Augusta, Georgia
    7,338
    Re: Salt Levels
    Is it making chlorine? If so, don't sweat it.
    A Taylor K-1766 salt test may put your mind at ease. You can get one sent to you from TFTestkits.net for about $26. I always monitor my salt level as my SWG isn't correct yet I'm too lazy to re-calibrate it. It makes chlorine just fine so I don't worry about it.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Salt Levels
    SWCG have a range they'll work with, if your high or low salt lights aren't on, and the unit is producing, enjoy the water. I know that sounds lackadaisical but sometimes it's just that easy. If the SWCG is happy, the number doesn't matter. It's just a number.
    NOW: If SWCG is complaining and not producing. Then depending on the age of the cell, it could be on it's way out or dirty.
    Mar 2016
    West Chester, PA
    7
    Re: Salt Levels
    Have had same issue Taylor shows higher salt level
    Windowman
    West Chester, PA
    25year old 36,000 Gunite with new quartz finish (2014), 1 1/2hp Sta Rite pump, 60sf Pentair DE filter,
    1hp Polaris 380 cleaner, SJ45 Circupool Salt Water Generator
