Results 1 to 7 of 7
Thread: Advice on Pool Math
    Captain 776's Avatar
    May 2016
    Thailand
    163
    Advice on Pool Math
    Please take a look at my results today.
    I don't understand how to interpret the values and what it says in the suggested FC levels. Please explain and help me there.
    My FC went from 7 to 10.
    I did increase my salinity from 2.7 to 3.3 and I turned my SWG up to MAX about a week ago.
    Today, I will turn it back to 70%.
    I don't understand the CSI Index and it says my number of .9 can be a problem for all pools.
    I think the answer to this question is yes, but when I add the recommended amounts of chemicals shown in Pool Math that it will either correct the CSI Index or at least give it different numbers.
    I am hesitant to add 835 OZ of Calcium Chloride all at once, so I will do it 50% and see where it is, then add again.
    Feedback here, will be greatly appreciated.
    Bruce
    8M x 4M X 2M no slope IG CONCRETE w/ceramic glass tile
    17,000 Gal EMAUX SWG JAZZI FILTER W/1-3 mm glass media, Jazzi Multi-port valve with
    T-750 filter w/ glass media
    1 main drain sump -3 returns - 1 skimmer
    Kokido digital salinity tester, Kokida drops for CL Hanna digital PH meter, Taylor K-2006
    Mod Squad pooldv's Avatar
    DFW, TX
    24,517
    Re: Advice on Pool Math
    Here is a tutorial for Poolmath, Pool School - PoolMath
    Why is 400 entered as the target CH?
    Salt has to be entered in PPM, yours should be around 3000-3500. What is 3.3?
    Your CSI is -0.9, negative CSI means that your water is aggressive and below -0.6 can cause calcium to be dissolved from the plaster. Tweak PH, TA and CH to adjust the CSI. If it is positive that means there is increased risk of calcium scaling.
    For FC Now is higher than Target so it isn't telling you to add anything.
    Jezza's Avatar
    Jan 2015
    Bunbury, WA, Australia
    894
    The numbers in 'Suggested FC Level's' change based on the CYA figure you put in to the 'Now' section of Poolmath as per the FC/CYA chart. You can see that if you change that number in the 'Now' column that it will change the numbers in the 'Suggested FC Levels' if that makes sense.
    With a SWG it is a good idea to aim for the slightly negative side of 0 for your CSI- perhaps around -0.1 or 0-0.2. Looking at your CSI numbers- the left side is the the CSI number you have based on your current test results and the right side is what it will be based on the 'target' numbers.
    11 000 gallons, IG, Fibreglass, Monarch Sand Filter, Davey Typhoon C100M 1HP pump, Davey Chloromatic Mc16CTO ESR SWG, Davey Pool Wall Climba Robot, Daisy Solar Cover,
    K-2006
    DFW, TX
    24,517
    Here is some more info on water balance for saltwater pools, Pool School - Water Balance for SWGs
    May 2016
    Thailand
    163
    Pooldv - "Salt has to be entered in PPM, yours should be around 3000-3500. What is 3.3? "
    My Kokido digital meter reads like that, it means 3300
    I was sick a few days but did add about 40 lbs of Calcium Chloride and I still need to add baking soda, I will get that done in the morning, let it circulate and then do a complete new round of tests.
    May 2016
    Thailand
    163
    I am getting closer step by step to an even balance.
    I am adding the recommended amounts slowly and not adding the total amount at once, but we have had substantial rains in the last 2 weeks.
    A few nights ago, my pool went up about 5 cm ( 2 inches) in about 45 minutes so a lot of the water went out the overflow tube.
    Today I will add the recommended doses but can't check CYA again until late August when I return from America and hand carry the reagents back.
    I do have a question, is having a FC value at 11.5 really a bad thing, having it a little high means you have less chance of growing algae? Is that correct?
    38,548
    You will lose a little more FC to the sun the higher you raise it, but it will not hurt anything being a little high. Most important to stay above the minimum.
