Thread: Need advice on run time and power setting
    DallasPoolMom's Avatar
    Jun 2016
    Dallas, TX
    11
    This is my first week without using my in-line chlorinator. Yay!
    FC 7.5
    pH 7.5
    TA 80
    CH 250
    CYA 50
    Crystal clear water!!!
    I've always had to run my pump 8-12 hours to make sure that I was getting enough chlorine. Now I'm thinking that I may not have to run the pump so long since I'm manually adding bleach. I have the pump set at 3000rpm on my controller because I have 2 scuppers, 2 bubblers, and spa waterfall on the one pump. (My Polaris does have a booster pump.)
    Does anyone have any suggestions or ballpark figures on proper power setting and run time? I've read some posts, but the technicalities are beyond my understanding.
    Here is my equipment information:
    Pentair Clean & Clear Plus Cartridge Filter Model CCP420/Filter area 420/design flow rate (gpm)150
    Pentair Intelliflo VS + SVRS Ultra Energy Efficient Pump
    22K gallon freeform inground pool with 9ft round spa with cascade
    2 scuppers in a 18" pool wall
    2 bubblers on tanning ledge
    2 skimmers
    Specs per pool builder plan
    pool line 2" & 1.5", suction 2.5"
    spa line 2.5" suction
    scupper lines 1.5"
    Thanks so much!
    22,000 gallon/Inground Freeform Pool w/ Raised Spa (2014), Midnight Blue QuartzBrite, Pentair Intelliflo Variable Speed Pump, Pentair Clear & Clear Plus Cartridge Fliter, Polaris 280 w/ booster, Ozonator, Intellitouch/Screenlogic, Bleach Chlorination, TF-100 Test Kit, City Water Source
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Need advice on run time and power setting
    This is the process I used (with great success): Determine Pump Run Time
    Jun 2016
    Dallas, TX
    11
    Thanks for the link. Do you know of a link that has recommendations for the flow rate setting? I'm sure that I have my settings all out of whack due to the filter pressure problems that I was having with an algae bloom. I was consistently increasing the flow rate using screenlogic without being able to chlorinate the pool sufficiently…I know why now but didn't at the time. Now that I have that issue worked out, I would like to set my system to work more efficiently.
    I may try calling Pentair on Monday. I cannot remember the pool builder's recommendation and cannot find any setting recommendations in my paperwork from him.
    Thanks again.
    mas985's Avatar
    Pleasanton, CA
    11,742
    Do you have the Intelliflo VS or VF?
    Do you use a pool cover?
    Do you have a lot of debris dropping in the pool?
    The short answer to your question is whatever it takes to keep the pool as clean as you like it. However, to save energy, you want pump speed/flow to be as low as possible. A little trial and error can help you dial in optimal values. But try 1000 RPM for a few hours and see if the skimmer are collecting the debris. If not dial up the speed. If you use a pool cover, then skimming doesn't matter. The pool cleaner probably becomes the limiting factor although the Polaris does need much in the way of flow rate.
    Mark
    Jun 2016
    Dallas, TX
    11
    Thanks
