Results 1 to 7 of 7
Thread: Augmenting SWG
    Aug 2009
    Flower Mound/Texas
    41
    Augmenting SWG
    I will be out of town for a few weeks and need to know if its ok to use the chlorine disks in addition to my SWG. My SWG is not producing chlorine fast enough as I wait to slowly raise my CYA. I don't want to come back to a green pool if I cant add bleach manually.
    Let me know what you think. When I get back, I will start over.
    Thanks
    Charlie
    18,000 gal SWG, pebble tech, Jandy filter, Jandy Aquapure
    Flower Mound, Texas
    Jan 2012
    'burbs of Augusta, Georgia
    7,368
    Re: Augmenting SWG
    Can you give us a set of test results to see if your pool can tolerate a little extra CYA?
    Also, what's going on with your SWG that you say its not producing enough chlorine? How long are you running the pump for? What % do you have it on?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: Augmenting SWG
    In addition to Yip's questions. Here are some more. How many PPM of CYA did you add, how did you add it and when? When are you leaving?
    Aug 2009
    Flower Mound/Texas
    41
    Re: Augmenting SWG
    yesterday at about 6 pm I added 1 gal of 10% chlorine and raised my SWG to 100%....I had added about 1 sock full (about a pound of CYA) a few days ago, tied in the skimmer ... I have just received more yesterday, but have not installed
    My readings as of this morning @ 7:15 AM with water temp @ 82 are as follows
    FC 2.5
    CC .5
    Ph 7.8
    TA 60
    CH 150
    CYA less than 20
    I am leaving early Wednesday morning
    Is liquid CYA a good alternative, I have about 14 lbs of solid CYA now
    Thanks
    Charlie
    Flower Mound, Texas
    DFW, TX
    24,514
    Re: Augmenting SWG
    Target 70-80 ppm of CYA. Granular is fine and a lot cheaper. If you get enough between what was already added and more to add up to 70 ppm in a sock or knee high and squeeze it a LOT today so that it will get dissolved today it should all be in the pool overnight and tomorrow so that you can get a decent read Monday and Tuesday on where to set the SWG to maintain FC. Then right before you leave lower PH to 7.2 if your PH tends to rise and raise FC up to shock level for your CYA, FC/CYA Chart.
    Aug 2009
    Flower Mound/Texas
    41
    Re: Augmenting SWG
    Thunderstorms for the last 2 days have not allowed me to get in all the CYA. I have added about 6 lbs and will try to get the rest in tomorrow. I imagine that my reading should improve tomorrow morning. I will base other additives on readings tomorrow.
    I am really starting to hate this rain.
    Charlie
    Flower Mound, Texas
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    Re: Augmenting SWG
    Off topic - We miss living in Flower Mound!!
    COMPLETED BUILD THREAD - 15'x29' rectangular offset shotcrete pool; 14,100 gal; 5'x7' raised spa with 400k btu fire feature; 7' spillover; 25' leuder stone raised bond wall w/waterfall; Pentair SWG; Pentair VS (pool); Pentair 3/4hp feature pump; 1hp spa blower; Pentair Cartridge filter; Pentair “Easy Touch 8” wireless; Dolphin Oasis Z5 robot; Solar Hydronics iSwim solar panels; Mansard Screen Enclosure; walnut travertine deck; 1 very happy kiddo.
