Thread: Waterfall Leak/sealant
    Jun 2016
    Santa Ana
    8
    I have a waterfall which is surrounded by rocks and it has a small leak. So far I have not managed to find the cause of the leak. Is there a brute-force solution? Is there a spray that I can line the waterfall with which will seal any leaks?
    Thanks
    Stu
    Apr 2013
    Sacramento, CA
    2,769
    Re: Waterfall Leak/sealant
    Is this a pool spa or pond?
    Jun 2016
    Santa Ana
    8
    Its from a waterfall - not accessible to swimmers.
    Quote Originally Posted by gwegan View Post
    Apr 2013
    Sacramento, CA
    2,769
    If the location of the leak is not somewhere where you care about looks then this is great:
    Pond Armour. Its an epoxy -- really ugly but it seals.
    Waterfalls and rocks often leak because the mortar tends to shrink. if you can go over the joints with some more mortar especially a fortified mortar then that may solve the problem
    Jun 2016
    Santa Ana
    8
    Thx gwegan,
    Is there a spray that I can use? I am not sure I will be able to get the paint in the corners.
    Jun 2016
    Santa Ana
    8
    Thx gwegan,
