Thread: loosing pressure
    loosing pressure
    So we have a Hayward sand filter. We had sand pumping into our pool so we replaced the lateral assembly, since then we have great pressure that last about 20-30 min then it starts dropping. we have checked out lines and primed the pump and still cant get to the bottom of the problem.
    Any help would be appreciated.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: loosing pressure
    Welcome to TFP
    if your pressure is rising **dropping** your filter is working like it should, it is filtering what is in your water..
    How does your water look
    what are your test numbers from your test kit
    let us know so we can get you going
    30,403
    Actually, I think you mean your pressure is increasing (on the psi gauge) but the flow of water is dropping.....please confirm.
    yes my numbers are
    cy 40
    th 150
    ta 40
    ph 7.8
    fc 2
    My pool was dark green with alot of leaves in it.(ripped cover) the leaves are out now, then out lateral assembly broke and was re[laced and now its short
    cycling. the water is cloudy and a pale green now. I am worried to slam the pol when I have to keep back washing it every 30 min.
    could it be just the cloudy water causing this??
