Thread: Should I add more bleach?
    nate81's Avatar
    May 2013
    Raleigh, NC
    190
    Recently refilled my pool.
    ph was around 7.4 and then i added CYA to get me to 70, baking soda to get my TA to 60
    Now i'm at....
    ph 7
    TA 60
    CYA (i'll assume its 70) I just added it yesterday evening
    Before I added the cya i added bleach to kill the tadpoles....then i came inside and read on here that I should not have done that.....i added one gallon @ 8.xx%
    Today, when I try to test my FC it won't turn pink. Should I assume now my FC is at 0 and dose accordingly?
    edit: I intend on using my SWG within the next week....as of now I am just using bleach. Thats why I'm trying to get my CYA up to 60 or actually i may have shot for 70
    double edit: I ran out and took a bonus pic of my crappy intex pool http://i.imgur.com/JvWPr8a.jpg
    Intex 16'x48" Ultra Frame
    Intex 2,650-Gallon Sand Filter Pump
    Intex Krystal Clear Saltwater Filtration System
    Taylor K-2006
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Should I add more bleach?
    Yes, no pink is 0 chlorine. Address appropriately. SLAM is the answer.... Pool School - SLAM - Shock Level And Maintain
    nate81's Avatar
    May 2013
    Raleigh, NC
    190
    Quote Originally Posted by bobodaclown View Post
    Thank you for the verification!
    Taylor K-2006
    nate81's Avatar
    May 2013
    Raleigh, NC
    190
    Added bleach to get me to 16ppm (thats all the bleach i had on me) went and bought 3 gallons this morning....tested again just now and it says i'm still at 16ppm, i have no idea how.....its very hot and full sun this morning. It says my CC is 0.....but when i added the bleach yesterday my water turned this slight yellowish/greenish color....
    Can I let my FC float back down now?
    Taylor K-2006
    May 2014
    Nevada, TX
    238
    Quote Originally Posted by nate81 View Post
    Not yet Nate, you need to keep SLAMing your pool and follow the process to the end. It is very important that you keep your FC up and try not to let it fall below the recommended shock level based on your numbers. I can tell you first hand, every time you allow your FC to fall below shock levels, your just adding to the TIME and MONEY you will spend getting everything straight again.
    It's important that your doing your overnight FC loss test to determine when it is safe to let the FC drift back down to normal swim levels. Keep it up, you will be glad you did!
    Good luck,
    Steve
    27'x54" Sharkline Venture
    Hayward X-Stream Full-Flo 150 sq. ft. Cartridge Filter
    Matrix 1.5HP Dual Speed Pump
    Hayward Aqua Critter Automatic Above Ground Swimming Pool Vacuum Cleaner AR500Y
    TF-100 test kit
    Isaac-1's Avatar
    SW Louisiana
    6,711
    The yellowish green color after adding bleach was likely caused by iron in your water, if it only occurs at high FC levels you may be able to live with it without much problem, if it gets worse you may need to consider adding a metal sequesterant (this is an ongoing process not just a one time addition, as it breaks down over time)
