Results 1 to 13 of 13
Thread: Mottled Plaster??
    Jul 2012
    Oklahoma City
    72
    Mottled Plaster??
    The plaster is getting a mottled tan/brown look. It's been getting worse the last 6 months.
    Today's water numbers are below. Pool store checked for metals-none. At 2 years old, I still have to add 1-2 cups MA daily or pH goes to 8.2+. Water-clear & 83deg.
    Any ideas what to do??? Thanks, Mark
    FC 4
    PH 7.8
    CH 450
    TA 100
    CYA 40 (low, SWG 55% at 8hrs/day)
    Salt 3500
    IG gunite Edmond, OK(OKC), 18x36 freeform ~20K, 4-8' deep, Pentair equip, (2) 3hp VS+ pump, 520 cart filter, 3 LED, Easytouch8, ItellichlorIC40 SWG, Polaris 3900 cleaner, Spa 8'x18"raised, 20' raised bond beam 2 sheers, Stonescape Tahoe Blue quartz plaster, TF-100 kit.
    Feb. 25, 2014 dig started, May 24, 2014 filled.
    Jan 2012
    'burbs of Augusta, Georgia
    7,336
    Re: Mottled Plaster??
    Get yourself some Vitamin c tablets and stuff them in a thin sock and hold it against a stained area. Does it remove the stain? If so its metals.
    In another stained spot- hold a chlorine puck against the area and see if after a few minutes if that doesn't lift it? If so its organic.
    You can often buy individual pucks at Lowes or the pool store. Vitamin C from drug store.
    Jul 2012
    Oklahoma City
    72
    Wow!! Thanks Skippy!!
    Vitamin C sock took care of a stain in about 60 seconds.
    What now? I hope there is a better way to fix other than me going all over the pool with the sock!!
    Thanks again.
    Jan 2012
    7,336
    Jul 2012
    Oklahoma City
    72
    Perfect!! Thank you, Sir
    Jan 2012
    7,336
    Quote Originally Posted by Flatlander View Post
    Ma'am actually Skippy is my other half
    Do you have any idea how you got metals in the water? Have you used copper containing algaecide? Do you fill from a well??
    Jul 2012
    Oklahoma City
    72
    Oops!!
    Lol, I knew when I posted, that would be the case!!
    Have a good weekend.
    Jul 2012
    Oklahoma City
    72
    And I have no idea how the metals got there!! No to both of your questions. Could it have been at startup? Is a sequestering agent usual? I know my PB did not use any. I think my plaster needs a startup acid wash too. It was done but has never looked right. In 90% of the pool the blue is hidden.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Some algaecides have copper in them. Another way to end up with copper in the water is a degraded copper heat exchanger (from the pool heater) or degraded copper piping.
    Love TFP? Become a
    TFP Supporter!
    Jul 2012
    Oklahoma City
    72
    I think my problems are Iron stains, as they can be removed w Vitamin C.
    And no blondes have turned green haired.
    Jul 2009
    Houston, Texas
    9,379
    Sorry, don't know why I was thinking copper. I've answered a few copper questions today! Do you have well water or old iron pipes? Those are the most common ways iron enters the pool. Fertilizers containing iron can also cause problems if they get blown into the pool.
    Love TFP? Become a
    TFP Supporter!
    Jul 2012
    Oklahoma City
    72
    No well water or old pipes.
    I have never seen any fertilizer streaks.
    Is there any relationship w the pool "eating" muriatic acid after 2 years?
    Leaching of iron from Okla red rock or rebar not encased someplace?
    Those are far fetched I know!!
    Jul 2012
    Oklahoma City
    72
    Moderator might want to move to Chemistry 201??
    Ascorbic Acid treatment started:
    6-23-16 FC1.5 PH7.5 Add 8c MA,16oz KemTech Algaecide
    6-24-16 FC 0 PH7.2 Add 1lbs AA at a time, 3 lbs total to rid stain, 32oz Magic's Purple Stuff
    6-25-16 FC 0 PH7.2 turn on SWG 10%, increase FC slowly
    6-26-16 FC 0 PH7.2 SWG increase to 20%
    6-27-16 FC 0 PH7.6 SWG increase to 30%, add 10c bleach
    6-28-16 FC 0 PH7.6 SWG increase to 40%, add 10c bleach
    6-29-16 FC 0 PH7.8
    0645 add 5c bleach, 1.5c MA
    0745 FC 0 add 5c bleach
    0845 FC .5 add 5c bleach
    0945 FC 1 add 5c bleach
    1045 FC 1 add 5c bleach
    1145 FC .5 add 5c bleach (sun is out caused drop??)
    CYA I am sure is low but I am waiting to get to FC 3 before adjusting.
    Any suggestions?? I want to dump 1-3 gallons of bleach in at one time but the TFP instructions stated to raise slowly. This is getting painful tho!!!
    Thanks for any advice!!!
