Thread: Repair for Pebble Pool
    Jul 2013
    Phoenix, AZ
    67
    Hello Team, I have a couple places around my pebble pool where the material has come loose leaving gaps. What is the best product to fill the holes. Thanks!
    10,000 gallon IG pebble pool, 1,200 gallon raised spa, built 2006, Hayward Mega Plus 700 cartridge filter, Hayward Northstar SP4015NS 1.5hp pump, Hayward Super II 2.5hp spa pump w/blower, Jandy AquaLink RS, SpaLink RS controller, A&A Quik Leveler, Quik Clean In-floor cleaning/leaf vac, Laars LX 400 heater, Fiberstars 6004 fiber optic light. Massive delamination of ShastaDeck cool decking.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Re: Repair for Pebble Pool
    Polyurethane caulk.
    Jul 2013
    Phoenix, AZ
    67
    Thanks Mr Mod Squad. Curious, why not a concrete material. I also have missing pebble and concrete around my boulders..
    DFW, TX
    24,513
    Because it is messy, hard to clean up and has no flexibility. For that spot anyway, it was likely caused by movement of the coping separate from the pool shell.
    Jul 2013
    Phoenix, AZ
    67
    Thank you Sir. Is there a brand that I should look for?
    DFW, TX
    24,513
    No, not really, whatever they have at your fave big box will be fine. That isn't a very critical joint.
