Thread: Will a Pentair vinyl liner plastic pool niche mount into the 2" Radiant metric wall?
    Egghead2004's Avatar
    May 2015
    Charlton, MA
    75
    I just received my Intellibrite lights for my pool today, but didn't realize the niche doesn't come with them.
    Now I am on the hunt for niches. I found Pentair Niches for vinly liner pools, but most pool walls are not 2" thick. Before I order these, does anyone know if the Pentair niches will mount to the 2" thick radiant walls?
    Thanks
    16*32 Radiant Metric Pool 8 foot walk in steps
    Pentair Intelliflow VF pump,Pentair 320 sq/ft cartridge filter
    Pentair IC-40 Chlorine Generator, Pentair Ulta Temp 110 Heat Pump
    Pentair Globrite LED lights, Pentair Easytouch 4 automation, Pentair Screen Touch
    900 SQ/FT stone patio under construction.
    Jan 2012
    'burbs of Augusta, Georgia
    7,306
    Re: Will a Pentair vinyl liner plastic pool niche mount into the 2" Radiant metric wa
    No, I don't believe you're meant to put those lights in your Intex pool. Those are meant for in-ground pools.
    Here are some ideas from Google- Google
    May 2015
    Charlton, MA
    75
    Ah, the Intex is gone, I am installing a new Radiant Metric pool. I'll remove the Intex from my signature.
    May 2015
    Charlton, MA
    75
    Found a solution. Pentair glowbrite LEDs fit perfectly.
    They are a small version of the intellibrites.
