Thread: New aboveground pool(bestway)
    May 2016
    East Wenatchee Wa
    5
    I got my bestway above ground pool set up and running for probably a month now and it has the sand filter and pump. I t shows high around 5 1/2-6 psi and isn't supposed to be over 4 1/2 psi. I called and talked to customer service and they said to backwash the system and if that didn't work to take some sand out and try that and I did but still high. Anyone else have any suggestions or had this problem. Thanks
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,052
    Re: New aboveground pool(bestway)
    Quote Originally Posted by jeremymarsh View Post
    I'd suspect a bad gauge. They all skimp on the gauge, and they use the same gauge on all the filters they make, so who says it's supposed to be 4? Every setup is slightly different. Just ignore those color bands and use the actual numbers.
    If it's filtering and you have strong flow, your clean pressure is 5-6 psi. You backwash at 8-8 psi. Problem solved.
    May 2016
    East Wenatchee Wa
    5
    The company and the manual says it needs to run about 4 1/2 psi and 5 1/2-6 is to high.
    Aug 2009
    SW Wisconsin
    518
    every gauge is different...listen to Richards advice..he KNOWS his stuff! Backwash your filter as per the directions and then put back into filtration mode...whatever PSI it shows is YOUR clean pressure. when it hits 8 or 9 psi..it's dirty and time to backwash. Again, every gauge and every filter is different, so a standard "set" of directions may work for one person, but not another.
    Good luck
    33' x 52" Swim and Play Inc. PARAGON AGP. Hayward H200 Heater. Hayward Power-Flo LX 1.5hp pump. Sta-Rite Cristal Flo T-210WF Sand Filter. Stenner 45M5 chlorine pump
    May 2016
    East Wenatchee Wa
    5
    Ok I just went back out and checked the gauge and I was wrong it says 8 psi not 5-6. So I bet I have a bad gauge iam going to call them back and have them sende a gauge. Thanks
