Thread: Help! New Hayward C900 Star-Clear Plus Going Over Pressure Every Day!
    Jun 2016
    Wethersfield, CT
    1
    Question Help! New Hayward C900 Star-Clear Plus Going Over Pressure Every Day!
    Hi! Last weekend we finally got our old Hawyard Sand Filter replaced with a new Hayward C900 Star-Clear Plus Cartridge Filter after it died when we went to open the pool the Saturday of Memorial Day weekend.
    The new filter and pump have been working fantastically, a notable difference from what we had before, HOWEVER, on day 3 the pressure gauge popped up over the 10 psi indicating the filter needed a cleaning. And then ever day since. When opened up, the cartridge hadn't been clean and spotless, but from what I hear, we should only really have to clean it 1-2 times a season. I am not sure just how dirty they can get before they need to be cleaned, but even for an opening, it seems excessive. Does anyone have any thoughts on this??
    Meanwhile we are struggling to get the pool clean which is hard when the water flow drops down due to the pressure change. We have run the filter 24 hours/day since it was installed. While our water is no longer green (yay), it is completely opaque despite our water analysis coming up balanced.
    We haven't been able to vacuum because we can't even see to know what we are doing. Anyone able to help would be my hero! We are dying to finally get into our pool before July for once!!
    Water Analysis as of 6/11/16 at 10:45 AM
    Free Available Chlorine (FAC): 3 ppm
    Total Available Chlorine (TAC): 3 ppm
    Calcium Hardness (CH): 250 ppm
    Cyanuric Acid (CYA): 35 ppm
    Total Alkalinity (TA): 90 ppm
    pH: 7.8
    Copper: 0
    Iron: 0
    Phosphates: 0
    Images of the pool are below:
    About My Pool
    10,000 Gallons, Vinyl Surface, In-ground
    Filter: Hayward C900 Star-Clear Plus 90-Square-Foot(Cartridge)
    Pump: Hayward SP2607X10 Super Pump 1-HP Max-Rated Single-Speed
    Open: Memorial Day to Labor Day
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Help! New Hayward C900 Star-Clear Plus Going Over Pressure Every Day!
    Welcome to TFP
    with that small of a filter you're going to be cleaning it every other day or more when you are doing a SLAM, it will work better once you are done killing algae but you may only get a month before you need to clean it... To give you an idea, I have a 100 sq ft cartridge on my 700 gallon spa and 320 sq ft on my pool, I only clean my pool filter once a year but I have not ever had to shock/SLAM my pool so I have no idea how long it would last cleaning/filtering algae (and I hope I never do)
    using the pool store to test is like driving blind, it may get you where you're going but it's going to cost way more money
    let us know if you would like some help on cleaning and maintaining your pool and we can go from there
    Jan 2012
    340
    Cartridge filters also offer better filtration, so you will be catching more debris in the C900.
    25K aggregate IG, Intellipro, FNS48, Polaris 360, PG2000 fiber optic light source
