Thread: Loss of pressure
    Loss of pressure
    Hello.
    I have a Polaris Caretaker system with the 5 port valves. Recently, when I turn on the pump it starts to push water into the "pre filter" just before the pump, but it never fully pressurizes. Then, after a minute or two, all of the water will suck out of the "pre-filter" basket housing and then this cycle starts again. Due to this "phenomenon", my pop ups never engage. I see no signs of leaks.
    I'm wondering if it sounds like the pressure relief valve is bad? What are typical signs of the pressure relief valve going bad? Any other ideas would be greatly appreciated. Thanks.
    AGP-11,800 gal-Vinyl-Hayward S180T90 High Rate Pro Sand Filtration System-Chlorease SWG CL02
    Re: Loss of pressure
    Seems like I have an air leak, and it's intermittent. The pump was working fine last night.
    Can anyone tell me anything about the pressure relief valve?
    mas985's Avatar
    Pleasanton, CA
    11,737
    What is the pressure at the filter and the pressure at the valve?
    Mark
