Thread: PH Testing and Reading
    Jun 2014
    Merrimack NH
    5
    Hi everyone,
    Quick question on reading the Taylor PH test.
    For the last two weeks every time I test for PH, as soon as I add the drops and shake it, the color immediately turns purple which would be a PH around 8.0. Then I wait for 10 to 20 seconds and the color settles in at 7.8. My question is should I be using the immediate reading of 8.0 or is it ok to wait the 20 seconds and use the 7.8 measurement?
    Thank you!
    -Matt
    26,000 gallon gunite pool
    FC 3
    CC 0
    PH 7.8-8.0
    Alkalinity 80
    Calcium Hardness 280
    CYH 30
    Borates 50
    Temp 72
    26,000 gunite pool
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: PH Testing and Reading
    welcome to TFP
    Use the very first color change, it may be over PH of 8.. using muriatic acid drop your PH and TA.. because you have added borates your PH and TA will move very slow so it will be a longer process to drop your PH...
    I hope this helps
