Thread: help pump seems to be working
    Jun 2016
    temple ga
    1
    I have a above ground coleman 1648. The pump is pumping ,everything seems like it's working,but my filter is staying somewhat clean. My pool is cloudly. I know it has something to do with the pump
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: help pump seems to be working
    Welcome to TFP!
    Cloudy water is nearly always a chemistry problem, not a pump problem. Usually low chlorine level results in cloudy water. Algae usually follows if the chlorine level is fixed quickly.
    Start here in Pool School, ABCs of Pool Water Chemistry
