Thread: Dripping aqualuminator gasket
    Hi all,
    I'm currently troubleshooting a small leak in my 24' above ground pool, drops about half an inch over night. The original installer misaligned the gasket on the outside wall of the light. It's been leak free until this year. Now that I'm snooping, I spotted a very slow drip under the light. Has anyone seen this before? The design seems likely to leak, but if everyone else's is bulletproof than I'll be more suspicious. I did find a leak at one of the hose connections which is now fixed.
    TomGallopavo's Avatar
    Apr 2016
    Hillbillyville, MO
    160
    Re: Dripping aqualuminator gasket
    I put mine in and it is not leaking though sometimes I wonder if I put in on too tight. Sometimes the directional turns easy, other times I struggle with it.
    Spring 2016 Install, 24'x54" Saltwater LX AG Round Pool (13500 gal.), AquaPro 200 SQ. FT. Cartridge Filter System 2-HP 2-Speed Pump, Solaxx Saltron Retro Jet RJ Saltwater Chlorine Generator, Aqualuminator Above Ground Pool Light, TF-100 Test Kit w/ Borate and Salt, Well Water.
    I noticed in the op manual, that the flow director should turn freely by hand.
    May 2012
    Montville NJ
    545
    It should not leak, it is no different in design that a normal eyeball. Make sure your gaskets are still live (not dried and brittle/stiff) and put a coat of pool lube on them (not petroleum jelly - that will eat rubber) get some pool lube at a pool store.
    My aqualuminator no longer works (I have had more issues with that thing - now the power supply has decided to call it quits) but I keep it in there beacuse the pool is hard plumbed to it.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    Thanks all. I found my leak - it was a tear in the liner on the far end of the pool from my deck. I also reseatted the gaskets for the light/return.
