Results 1 to 17 of 17
Thread: What is best way to cool our water?
    Chasmengr's Avatar
    May 2016
    Omaha, NE
    156
    Temp in our newly filled Radiant Metric pool has risen from 76F to 87F in one week (sans heater). Ambient daytime highs = mid 90's; ambient nighttime lows = mid 70's. Pool gets 80% sun most of day. Wx is supposed cool down and rain some next week. Humidity here is high, so evap cooling doesn't work real well.
    Fountain will lower temp but won't it raise pH, too?
    Chas & Cheryl (first-time, third-year pool owners)
    Radiant Metric Oval AGP 16'x32'x52"; Pentair: Clean&Clear 150 Cartridge, OptiFlo 1.5 Hp 2-spd, and 320C Feeder (all mounted below water level); Taylor K-2006 & SpeedStir; Maytronics Dolphin E10 (aka Einstein)
    installation pics (2015-2016)
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: What is best way to cool our water?
    Yes, aeration will raise PH and cool the pool. Especially if you run it at night. Lower PH with muriatic acid, Pool School - Recommended Pool Chemicals
    Chasmengr's Avatar
    May 2016
    Omaha, NE
    156
    Thanks! Just thought I'd ask, being a newbie and all . . .
    DFW, TX
    24,450
    Right on!
    Jan 2012
    'burbs of Augusta, Georgia
    7,273
    Check out Skippy's pool cooler fountain- link in siggy line. Worked wonderfully for us.
    Chasmengr's Avatar
    May 2016
    Omaha, NE
    156
    Your New Fountain looks fabulous. Thanks!
    Sep 2015
    Rome, NY
    363
    Cool it?? Lucky you.
    Refreshing 70 degrees just now. Now I'm sitting in the garage hoping to warm up LOL . Crazy five year old!
    Pool installed 8/2015. 30' round Radiant pool. 21,000 gallons. 200# sand. Hayward Vari flow XL valve. 1.5hp Hayward Power-Flo Matrix running 10 hours/day in two periods. TF100 with speed stir. Sun all day, south side of house
    Order test kit TF-100 w/ Speed Stir and then Poolmath Calculator --- RECOMMENDED LEVELS --- POOL SCHOOL --- Algae? --- Chlorine/CYA CHART.
    Jun 2012
    western NY
    1,559
    We really need to figure out how to do water swaps with people who have cold water.
    I have 6,000 gallons of 70 deg water. I am willing to trade 3,000 gallons of it for 3,000 gallons of 90 deg if any one has any.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Sep 2015
    Rome, NY
    363
    LOL. At least u have a heater.
    Chasmengr's Avatar
    May 2016
    Omaha, NE
    156
    Fountains arrived today. Cheryl wants two floating ones. I hooked up one today. Soon I'll get some tube fittings and hook up the second in a balanced flow piping arrangement so they both act the same. The pump is on low speed; high speed is way to much without some adjusting.
    Sorry cold-water guys, I didn't see your water trucks come by . . . (my water temp today is 92F; hopefully it'll come down overnight.)
    Mar 2014
    south central PA
    112
    92 degrees. 92 degrees!!!!
    Ours is currently sitting at 74. Too chilly for me. I've been researching heating methods all morning...
    Your fountains look great. Hopefully they will do the trick with cooling. What type of fountains are they?
    28 ft round ABG with ~6ft deep end, approx. 20,000 gal, 2 spd 2 HP pump, sand filter
    Chasmengr's Avatar
    May 2016
    Omaha, NE
    156
    Temp is at 86F this morning - fountain cooling is working Pool hasn't been at 86 since passing through during warm up weeks ago. Now I need to check pH. Sun will likely warm it back up some today, but seeing 86 is great especially with only one fountain at low pump speed.
    The fountains are the least expensive floating fountains we could find: Triple Tier Grecian. It's directions suck but after figuring things out, it works great. It does move around in the pool a bit; if it should get close the wall it would spray water out of the pool . I have an idea how to weight it down better so it won't move around, and to connect two fountains together.
    Aug 2014
    Baton Rouge
    7
    I hooked up my pvc fountain that looks kind of like skippy's last night. Pool temp yesterday was 95 degrees. Have a pool party on Saturday and hope to get it in the 90 range.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,754
    Mine is sitting at a nice 85 too bad I'm stuck at work.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Oct 2014
    Beaumont, CA
    47
    Im running a submersible pump through 500' of black " tubing and i can barely get 82. Without it drops to about 78, and our daytime high is 90-95. How do people get their water so hot without heaters? Im in CA where its usually dry heat. Is it the humidity? Id love to have that problem
    16x48 Summer Escapes Pro-Series Above Ground frame pool, 5000 gal, Intex sand filter - Looking for heating solutions for AGPs
    DFW, TX
    24,450
    Solar cover and/or solar panels. An 8mil solar cover makes a big difference keeping the heat in over night.
    Chasmengr's Avatar
    May 2016
    Omaha, NE
    156
    Not absolutely sure why our pool heats up, but during liner install weeks ago (ambient temp = 80F), liner got so hot from sun that it was burning our bare feet. We stood on pieces of cardboard so we could work; even then feet were hot.
    Our pool is Radiant Metric, which has insulated sidewalls, and we use HeatSavr liquid solar blanket; both may be keeping water warm overnight. Our daytime ambient RH is usually in the 60s%, so humidity may be keeping pool hot, too. Water temp this a.m. is 84F so fountain seems to be working
