Thread: Which chemical cocktail is the best?
    New to pool ownership.
    Pool seller suggested using tabs in free floating delivery system - PPM never gets above 10.
    Put the tabs into the skimmer may cause damage to the skimmer - PPM gets to 15 PPM.
    Friend uses shock every night and uses pool the next day
    Brother uses EZ Pool product plus granular chlorine.
    There seems to be many ways to use chemicals and hundreds of choices. What is the best practice?
    Guest
    Re: Which chemical cocktail is the best?
    Click on the pool school link in the upper right corner of every page (and in my sig) and read everything in it. Now read it a second time. After you are done post any questions you might have.
    Here is a post that you might find helpful:
    alternative-sanitizers-and-chemical-free-pools-the-truth-t3025.html
    Also, saying that FC will not rise above 10 ppm when useing a floater and will rise to 15 ppm when in a skimmer is incorrect. The BIG fact neglected is that trichlor tabs will cause the CYA (cyanuric acid) to rise and the pool to eventually become overstabilized. (Each 10 ppm of FC added by trichlor also adds 6 ppm of CYA).
    IF the granular chlorine you brother is using with EZ Pool is dichlor then the CYA will rise even faster than with trichlor tabs! (for eadh 10 ppm fc added by dichlori you are also addind 9 ppm of CYA!) If it's cal hypo that causes calcium to rise, which may or may not be a problem, depending on your fill water and other factors.
    IF you are talking about E-Z pool Powder from API water products http://www.apiwater.com/faq.php?prod_id=1 it is not a recommended product.
    anybody-have-experience-with-ez-pool-chemicals-t11050.html
    It is a copper sulfate based product. (In other words it's a very expensive algaecide that can stain your pool.)
    If you are talking about 'the liquidator" from Hasa for sdispensing liquid chlorine (or bleach, they are the same thing) http://www.ezpool.com/ it is a recommended product.
    There is no BEST way to chlorinate. There are tradeoffs to every method but we have found that using liquid chlorine or laundry bleach has the fewest side effects and is the most cost effective. However there is more to pool maintenace than just chlorine and if you ignore the other parts of water balance you will end up with problems.
    That is why we are here, to help you every step of the way without trying to sell you a product!
    30,424
    Welcome to the forum.
    By far the best practice is to understand the basics of pool water chemistry. Armed with that knowledge (available up in Pool School) you can manage your pool in a variety of ways and you will know the outcome prior to any addition of chemicals. In other words, no mysteries or, worse yet, surprises.
    FWIW, it's also the cheapest.
