Thread: Correct plumbing on my pool?
    Oct 2010
    michigan
    284
    I have 15x40 foot sports pool, 15,000 gallons
    1 skimmer, 2 main drains
    2 returns
    All above using 1.5 inch pvc coming into the valves, Then switches after the valves to 2 inches to the 1.5hp 220v pump into the 350lb 75gpm sand filter, into pool heater then switches back to 1.5inches after the valves back to the pool.
    Is this sufficient plumbing?
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: Correct plumbing on my pool?
    It should be fine. I don't know why they didn't stick with 1.5 connections for the equipment but switching to 2.0 shouldn't cause much difference. Are you having issues with circulation?
    Love TFP? Become a
    TFP Supporter!
    Oct 2010
    michigan
    284
    Nope just wondering from reading all the forums. Just wondering if the 1.5 inch pvc is sufficient enough.
    1.5 inch main and 1.5 inch skimmer into the jandy valve out 2inc into pump,filter heater, makes sense to me.
    Just wanna make sure everything is suffiecient, reading the forums too much, lol
