Had all my levels in tip top shape for the last week. Went to check chlorine levels this morning to make sure I didn't need to adjust the output on my generator with the sunnier days and higher bather load. Come to find out, chlorine was at ZERO. Went into the SwimPure Plus generator and all lights were off. I have troubleshooted this problem via the forum and have ordered a current limiter. Hoping that will be the fix. But, I got nervous knowing that chlorine was at zero. I quickly added enough liquid bleach to get me up to 4. The water is a little cloudy but there was a lot of activity in there last night. Nothing I would be alarmed with if chlorine wasn't at zero. My question and request for opinion; do I need to treat the pool any different then I have? I just added enough chlorine to get me into the appropriate level; should I be doing more in anticipation of some currently unforeseen issues that may be lurking? Thank you.
