Thread: Operating pressure
    Jun 2007
    Eastern NC
    Operating pressure
    How important is it to backwash a DE system when it reaches the 10psi point from initial setup? How much farther past the 10psi can it go safely? Reason I'm asking is I'm at 8psi above now and was wondering if I need to backwash tonight or could it wait until I get home from work tomorrow. DE system is new to me.
    Oh and is making a DE slurry necessary or can it just be added straight to the skimmer basket? My neighbor just adds to the skimmer but I want to make sure I do this right and not go on what someone else is doing that might be wrong.
    24k IG Vinyl D.E. Filter, SWG
    It will be just fine for you to wait.
    I always just added it to the skimmer. Not all at once. 1 or 2 lbs at a time with the pump running, it always slurried right up by itself, for me.
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
