Hi guys,
I've been lurking here for a few months, but this is officially my first post!
I bought a house last August that came with a 16,000 gallon in ground saltwater pool with SWG.
The pool looks great except for a little bit of algae that has started to grow after some recent very heavy rains.
I went to Amazon and picked up a FAS-DPD kit after reading some of the posts here.
Today I ran my first set of tests and I'm pretty horrified by the results.
Any advice as to what I need to do (amount of chemicals needed) to get these levels in the desired range would be much appreciated!
Here are the results...
Salt 2800
CYA 0
FC 0.5 - 1
CC 0
TA 125
PH 8.0+
CH 225
I've done enough research to know where each of those levels should be and have a rough idea of what chemicals are needed to adjust each reading, but I want to make sure I buy the right type and right amount of each and also want to make sure I adjust each level in the right order.
Thanks for reading!
Dregu
Salt 2800
CYA 0
FC 0.5 - 1
CC 0
TA 125
PH 8.0+
CH 225
Thanks for reading!
Dregu
