Thread: What kind of pump do I need to drain the water under the pool?
    Aleforge's Avatar
    May 2014
    Wentzville, MO
    149
    I have a white pipe sticking out of the ground that was guessed (thanks Richard) to be a well point pipe (in ground pool). My pool is being crushed by the high water table (literally). I have a crack on the bottom and the floor is bulging. SO I am crossing my fingers that this is a well point, and I can use it to drain the area underground around the pool. It is a 1 1/2 to 2" PVC pipe (capped). I opened the cap and there is water up to the top. It doesn't have a pump underground, but I searched and it seems like some of these are "suck" type.
    My question is what type of pump do I need to drain it? And how does it work? Doesn't seem a sump style is going to do me much good.
    Thank you!
    In ground (installed 2000), fiberglass, cartridge filter, Pentair Super Flo Single speed pump (2014).
    Apr 2013
    Sacramento, CA
    2,769
    Re: What kind of pump do I need to drain the water under the pool?
    Look at trash pumps they come in various sizes.
    Maybe something like this
    Liberty Pump, Centrifugal, 1/2hp 331 | Zoro.com
    Aleforge's Avatar
    May 2014
    Wentzville, MO
    149
    Thanks for the link!
    I came across this since posting, is it too small. The spec sheet says it can 240ish GPH at 15 feet depth. I only ask because its 69 bucks.
    Wayne Transfer Pump
