Thread: Odd pipe sticking out of ground, what is it for?
    Aleforge's Avatar
    May 2014
    Wentzville, MO
    149
    I have this PVC capped pipe near my pool and I always wondered what it was for? Any ideas?
    http://i.imgur.com/fSKZ3AC.jpg
    http://i.imgur.com/JRbpjaf.jpg
    Thanks!
    In ground (installed 2000), fiberglass, cartridge filter, Pentair Super Flo Single speed pump (2014).
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: Odd pipe sticking out of ground, what is it for?
    Most likely it's a well point left from construction. If the groundwater is too high, they need to pump it out and away while they're working in the hole. Until the pool is full of water, it could float up.
    Use the search box upper right for well point and read all about it.
    Aleforge's Avatar
    May 2014
    Wentzville, MO
    149
    I am having major issues at the moment, the floor is bulging and a crack formed. As well as some side bulging. We got a TON of rain over the winter and many in my area ended up with problems. Do you think this could be used now to pull the water away from the pool, and help save it?
    Thanks!
    Richard320's Avatar
    Jan 2010
    19,075
    Quote Originally Posted by Aleforge View Post
    Thanks!
    Possibly. You're asking the wrong guy, though.
    What is rain?
    Aleforge's Avatar
    May 2014
    Wentzville, MO
    149
    I did a search like you said and read through some. Most people are talking about a submersible pump, but one response said there were "suction" types. I am not sure how to use it though, if you stick a long pump house down it?
    Rain, umm.
    Thanks Richard!
