Thread: CYA Test
    May 2015
    Toronto
    183
    CYA Test
    Hi,
    I have the K-2006 and it requires a 7ml sample of 1:1 dilution with r-0013 for testing.
    I bought a separate tube for CYA testing from TF-Kits and when I use the sample I made, it doesn't work well with this tube as I don't have enough liquid? Does this tube use a larger sample size? If so, which measurements do I use? And can I use a graduated cylinder to measure it out with the speedster?
    please advise,
    23K gal (I think), IG vinyl lagoona, Sta-Rite Hi-Rate Sand Filter T-240BP-1, Pentair Superflo VS 1.5 Pump (342001), June 2007, Taylor K-2006, Hayward Chlorine Feeder CL220, Water source from garden hose w/ water restrictions | 1HP Sta-Rite DYNA-GLAS MPRA6E-147L single speed pump
    30,431
    Re: CYA Test
    The view tube for the TF-100 does use a larger sample size and it goes down to 20 ppm instead of only 30 ppm as the K-2006 does.
    The amount used should be 15 ml for R-0013 and 15 ml for the pool water.
    May 2015
    Toronto
    183
    Re: CYA Test
    Thank you! Could I use the cylinder? Or do I need a special mixing bottle? If the pool is under 70 f would that affect results? And how?
    38,475
    Re: CYA Test
    Sure you can mix it in a cylinder.
    Cold water just slows the reaction. Best to let the sample warm to room temperature before the test.
    May 2015
    Toronto
    183
    Re: CYA Test
    When I tried using the standard with the tf-100 tube I can like 30 as opposed to the k-2006 tube I get 50
    30,431
    Re: CYA Test
    As you are discovering, it is a bad idea to mix testing reagents and hardware. I am not sure what you are trying to accomplish nor can I figure out why you got those results.
