Thread: I have a question about adding DE to filter.
    jimmcg29's Avatar
    Mar 2009
    Lower West Michigan
    21
    From what I understand adding DE to a sand filter creates a small layer at the top of the sand and catches all the fine particles. That means it is also catching anything bigger. Is there anything left for the sand to do? It seems to me the ideal thing to do would be adding sand to the filter until get you above the laterals, thin layer of DE, and fill it the rest of the way with sand. That way the sand gets the big stuff the DE gets the little stuff. I am guessing the DE will stay put when you backwash or it wouldn’t stay put during normal filtering.
    30,431
    Re: I have a question about adding DE to filter.
    I can't imagine that working but it sounds like a great experiment you could try. It might just work! Report back your results
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,050
    I nominate you to be the experimenter.
    My fear is that if the sand layer isn't deep enough that some of the DE will find its way through the sand bed and into the laterals and out into the pool.
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    It takes so little DE to start raising the pressure. I would keep a super-close eye on the gauge during any experiments.
    * 18' x 33' - 48" oval AGP - new liner Summer 2014
    * Hayward Pro Series S210T Top Mount Sand Filter
    * Hayward Power-Flo Matrix 1 1/2 hp Pump Model SP5615
    (equipment on posts prior to summer 2014) Hayward PowerFlo 1 hp pump - Jacuzzi "Tidewater" 190L, sand filter
    Donldson's Avatar
    NW Ohio
    2,916
    Well, I certainly wouldn't stop you from trying, but DE does eventually "go bad". The diatoms trap particles quite effectively and eventually become overloaded and must be removed. That is why DE filters dump the DE when they backwash and new DE has to be added. My guess is that your DE layer will start to clog at some point and you won't be able to get the DE out if it is trapped between layers of sand.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
