Thread: Pool Hoses Leaking, Going to attempt to hard plumb today hopefully
    Jun 2014
    Aberdeen,MD
    39
    Hi all,
    So over the past few days, I've had major complications with the regular old hoses that I've been using for several years now. For some reason, they just aren't fitting properly this year, as they have in the past. Not sure why.
    Anyway, after a good bit of research, it seems that hard plumbing is the way to go as it is more efficient, more attractive, and easier to maintain.
    Could someone experience provide some information on what type of pvc pipes, fittings, etc. I will need to complete this? As well as any advice.
    Is this something that I should be able to do in a day?
    Jared
    10K GAL, AGP Vinyl, Pentair Sand Dollar (SD40) filter, Pentair Dyanamo High Performance Pump (DYNIIN1-1)
    HP 1.50 SPL, Kreepy Krauly Lil Shark Pool Vacuum, Taylor K-2006 Test Kit
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Pool Hoses Leaking, Going to attempt to hard plumb today hopefully
    jared, you can easily do it in a day
    you can use this piece for hard pipe
    Amazon.com : Hayward SP1023G Vinyl Fiberglass Inlet Fittings for Pools, Spas and Hot Tubs : Swimming Pool Maintenance Kits : Patio, Lawn Garden
    1.5 inch use these unions these will also work for your skimmer and should work for your pump if they have 1.5 inch connections..
    Custom Molded Products Union 1.5 Slip - 21063-154-000 - INYOPools.com
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    You can have a look at what I did to my Franken-Intex pool for hard plumbing.
