Results 1 to 10 of 10
Thread: Pool floor feels like a water bed (fiberglass)
    Aleforge's Avatar
    May 2014
    Wentzville, MO
    149
    I posted here a bit on my fiberglass crack problem I got surprised by when I opened a month ago. I ended up taking the advice to fill in the crack with marine epoxy for a temp fix. I got that done yesterday, however it was the first time I actually set foot in my pool this season. When I step on the floor its like I am walking on top of a waterbed. My buddy was in with me helping and when either of us would put weight on the floor the other one would feel it move. The only place that was still rock solid were the corners and steps.
    I am trying to visualize whats happening. I am guessing my pool is trying its hardest to float out but the sides and water are holding it down. Which also lets me believe the water table is very high? So the crack was large, 3 x 12 inches or so (tapered). But the pool never lost any water over the past month. It actually seemed to lose less water than it should have via evaporation.
    Long story short can someone help visualize what is going on? Is it possible plugging the hole could make it worse and crack other places? And any idea what could or has to be done at this point?
    Thank you!
    In ground (installed 2000), fiberglass, cartridge filter, Pentair Super Flo Single speed pump (2014).
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Pool floor feels like a water bed (fiberglass)
    It sounds like the water is below the pool and you are probably correct on it trying to float, the water inside the pool is keeping it down... You need to install or have someone install a sump pump outside of the pool as close as possible to the deepest end and pump the water away from the underside of the pool...
    Aleforge's Avatar
    May 2014
    Wentzville, MO
    149
    Thank you for responding! So along the deep end wall it would need a hole dug along its side until you hit standing water? And would this be a permanent pump? I am wondering how it keeps from getting clogged up buried under ground, or maybe it slides down into a small well?
    Do you think adding more water to the pool would be a good idea to add weight? Not sure if you can go up to the skimmer top.
    Thanks!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    As a fiberglass gel coat fails it becomes less and less watertight and allows more and more water to penetrate into the layers of the fiberglass. Sounds like it might be time for a new gel coat.
    Jul 2013
    Fletcher, OK
    3,353
    Quote Originally Posted by Aleforge View Post
    Thanks!
    This is what I am talking about, they are a pain to install afterward but worth the expense..
    Aleforge's Avatar
    May 2014
    Wentzville, MO
    149
    Quote Originally Posted by pooldv View Post
    Ya the pool is 15 yrs old (owned it for 2). Is that something crazy expensive?
    DFW, TX
    24,514
    I don't know. Maybe someone else will chime in who has done this before.
    The fiberglas pools from a factory are usually covered in acrylic. I suspect that the acrylic layer has delaminated from the fiberglas and there is water in between the two.
    Fiberglas that has been applied after the fact, usually has a gel coat, which is just a layer of resin with no glass fabric.
    Is your surface acrylic or gel coat?
    Support the site
    Aleforge's Avatar
    May 2014
    Wentzville, MO
    149
    I have no idea what it is, the owners left very little in the way of information. I am going to go dig back through some old stuff and see. Is acrylic repairable (re coat-able) or can only gel coat be reapplied?
    Probably need to contact the pool manufacturer to see what options are available.
    Support the site
