Thread: Frequency of replacing sand in filter
    nachos23's Avatar
    Jul 2015
    Whitby
    17
    I've been getting higher pressure readings on my sand filter (avg 15-18 psi) than most of my neighbours who seem to be around 8-10psi... Having just bought the house last yr, I've spoken to the pool maintenance company that's serviced this house for the past 25 yrs and they show no record of ever changing the filter sand in the filter.
    I've heard varying stories in regards to the frequency of changing the sand.
    Can anyone clarify the correct frequency for changing the sand?
    I do backwash and rinse after pretty much every vacuuming of the pool...
    Not sure that this makes a difference, however, it was a non-saltwater pool (close to 30 yrs) until last yr when I converted it...
    Thanking in advance
    Bill
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    495
    Re: Frequency of replacing sand in filter
    No need to ever change your sand. The following link will explain how to clean it.
    Deep Cleaning a Sand Filter
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    every pool has a differant PSI and sand has been around for millions of years do a deep clean and you should be good to go, the sand will last longer than the filter
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    There is no normal filter pressure. Pressure is dependent on many things plumbing, heater, return eyeball size, number of 90 elbows, valves, etc. It is recommended to backwash your filter when pressure rises 20-25% above clean pressure.
    nachos23's Avatar
    Jul 2015
    Whitby
    17
    thanks everyone. I'll follow the link above and learn how to deep clean the sand...
    Jan 2012
    'burbs of Augusta, Georgia
    7,364
    Sidenote: a slightly dirty filter works better than one repeatedly backwashed.
