Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Summer waves pool help
    Jun 2016
    Denham springs
    11
    I just purchased a summer waves 18x48 pool today. I also bought an intex 2800 sand filter pump and a saltwater system. I put up the pool today only to see I don't have pool plunger valves I need for my intex pump ( I thought it came with the pump since I don't have an intex pool). So that's problem one. Problem two is I don't even know where to begin to attach the sand filter pump to my pool since the new summer waves pool has a different skimmer with a closes in system so the way I though I was going to do will not work with my adaptor I purchased from amazon. I need to figure out how to either buy something to attach the hoses together or replace the skimmer on the pool with another one that will fit the intex pump. Im at a stopping point right now with my pool halfway full not knowing what to do
    Jun 2016
    Denham springs
    11
    Re: Summer waves pool help
    Also do I need the plunger valves or is there a way I can purchase something to not use them since I want to keep my skimmer.
    Will the pump and skimmer just let water flow through it also once I figure this out or will I have to run this pump also to let water come through
    Jun 2016
    Florida
    10
    There is an attachment on Amazon for removing the pump so you can attach a hose. I've read that you can also just plumb with the pump in place and remove the impeller so the flow is not restricted. How do you like that pool? I was thinking about getting it over the Intex because it has less holes because of the skimmer.
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    573
    When I had my summer escapes pool this is a general overview of how I hooked mine up.
    I removed the impeller from the pump on the skimmer. That was before I found out there was and adapter to do away with the pump all together. I never got the adapter and it ran like this for 6 years. Even after upgrading to a larger pump and filter it still worked fine.
    BTW. I only used one plunger valve. Just to get from thr skimmer to the pump.
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    Jun 2016
    Denham springs
    11
    Quote Originally Posted by Jamison04 View Post
    How did u remove the impeller? Also my motor is in the inside not outside on the new skimmer, will this still work just use the original hose to the plunger valve? Or did u have to buy an thing else for the attachment? The plunger valve just hooked up to your pool hose or you used a different one? Sorty I'm just so confused?
    Jun 2013
    Seguin TX
    192
    Those intex valves "old ones you are showing" are horrible, they can really restrict the water flow and often break very easily. I like the newer Intex valves that have the rectangular valve on top and screw in and out instead of those with the handle.
    2017-Intex Ultra Frame 16x48 5000 Gallons
    Intex 2800GPH Pump with 14" Intex Sand Filter
    My Intex Pool Setup Video :Intex pool rises from the ashes - installing and leveling - EP-72 - YouTube
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    573
    Quote Originally Posted by Bliotto View Post
    Well with the pump being on the outside it was serviceable to replace the impeller shaft.
    I wasn't aware that the pump was in the skimmer. What does the bottom of it look like where the hose comes out to go to the return? Is there any way to use that hose and hook it to the pump via a plunger valve similar to what I did? And then just use the intex hoses with the screw on ends to connect everything else?
    Jun 2013
    Seguin TX
    192
    Do yourself a favor and purchase this item
    Amazon.com : Summer Escapes Skimmer Filter Pump Conversion Kit : Swimming Pool Skimmers : Patio, Lawn Garden
    This will allow you to remove that old pump body from the skimmer, increasing your flow. And change out those old Intex valves for these.
    Amazon.com : New Model Set of 2 Intex Large Pool Plunger Valve Assemblies : Swimming Pool Pump Accessories : Patio, Lawn Garden
    These valves are less restictive than the ones you are using, and better made in my opinion.
    Jun 2016
    Denham springs
    11
    With the motor being in the skimmer Im not sure I can remove it. The bottom is a screw on. Bottom with the hose coming from the side. I just order the newer plunger valves and the intex parts recommended above, but the piece for the conversion from amazon will not work for the new pool since the motor isn't on the bottom anymore.
    I'm going to try to use the hose to a plunger valve like above and hopefully that will work. If I don't remove the impeller though will the water flow through the pump without the original pump plugged up or do I have to open up the motor and see if I can remove the impeller?
    Aug 2015
    Tuttle Ok
    27
    I just got one of these new Summer Escapes Elite pools. I Bought a Hayward Skimmer and put it on instead of using the one that came with it. After installing the Hayward skimmer, I used the Intex Plunger valves Using these Adapters:
    Amazon.com : Intex Soft Side Pool Short Connection Kit - 40 Millimeter to 1.5 Inch : Swimming Pool Hoses : Patio, Lawn Garden
    After that, I hooked up a 2800 GPH Intex sand filter and SWG using the supplied hoses that come with the Intex Pump.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Welcome to TFP brunnesa! Thanks for that helpful post!
    Aug 2015
    Tuttle Ok
    27
    Quote Originally Posted by pooldv View Post
    Thanks. I ran into the same issue that Bliotto has when I got this Summer Escapes Elite Pool. Here is a picture of the Skimmer that comes with these pools.
    The pump motor is totally enclosed in the skimmer unlike the other summer escapes skimmers where the pump attaches to the bottom of the skimmer.
    Jun 2016
    Denham springs
    11
    Quote Originally Posted by brunnesa View Post
    So do I even need the other parts every recommended the intex parts above cause I already order them.
    Also did u have to cut the pool for the new skimmer? Can u link the one you purchased?
    Jun 2016
    Denham springs
    11
    Also I'm trying to bot install a new skimmer if I could. Is there no way to open the motor and remove impeller on this model of pump? Because like I stated I got the other pieces above. I just don't want to have to cut the pool. I'm worried about it leaking.
    Aug 2015
    Tuttle Ok
    27
    I do not know if you can remove the impeller or not, but I can take a look tonight and let you know my opinion. Others will probably have an opinion on that also. I do think it might be difficult to attach the 1.5'' intex plunger valve to that skimmer. If you decide to change out the skimmer, here is the skimmer I purchased:
    Amazon.com : Hayward SP1091LX Dyna-Skim Above-Ground Pool Skimmer and Accessory Kit : Swimming Pool Skimmers : Patio, Lawn Garden
    You will need these plunger valves:
    You will also need these adapters:
    I understand your reservations on cutting the pool liner, but the linked above skimmer's opening is just barely bigger than the one provided with the pool. Really the only cutting needed is going from the round hole from the provided skimmer to the square hole of the hayward skimmer. They provide a gasket with the hayward skimmer. I have no leaks.
    14'X42'' Summer Escapes AGP
    2800 GPH Intex Pump with Hayward S166T Sand FIlter and Krystal Clear SWG
    TF-100 Test Kit w/K-1766 Salt Test and Speedstir
    Jun 2016
    Denham springs
    11
    I'm going to order the skimmer thank you.
    One last question the salt water system u have did u need any parts for the return into the pool? Or did u just leave the one it had?
    chayne's Avatar
    May 2016
    Somewhere Around The Red River, Texas
    336
    i did not use the plunger valves. i just used 1.5" pvc ball valves when i switched over to hard plumbing.
    Charles
    Coleman 16'x48"
    Intex 16" pump & Sand filter, Intex Robot Vacuum
    Hayward Wide Mouth Skimmer
    TF-100 Test Kit Magnetic Speed Stirer
    Aug 2015
    Tuttle Ok
    27
    I used the supplied return that came with the Hayward kit that I linked. I then used the other adapter like this to attach the other Intex valve (it has 2 in the package):
  20. Back To Top    #20
    Aug 2015
    Tuttle Ok
    27
    I also have figured out that you can use your existing skimmer and attach the sand filter and pump. As someone mentioned earlier, you remove the impeller:
    After that, put everything back together without the impeller.
    Then use one of these adapters on the output of the skimmer to attach the Intex plunger valve. If you buy the Intex Saltwater generator, there are two of these adapters included.
    Amazon.com : INTEX 1.25 Garden
