Thread: Electrical Question, can I wire a pair of 120v 15v or 220v outlets to a Intermatic?
    Oct 2015
    Dallas
    123
    Its a fairly simple question and mostly an electrical one. I'm looking to get a Stenner pump but would have to either direct wire them straight to the pool intermatic, or add a pair of outlets to the system.
    Fairly simple question, can the wire that feeds the intermatic support a pair of outlets for a pair of stenners? If not or (we don't know because your setup), how could I check or determine that. Yes I have a volt meter.
    No I don't know if its a 120v or a 220v yet (will check tomorrow).
    Thanks.
    Inground Gunite/Plaster pool with spa. Estimated 31,000 gallons.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,733
    Re: Electrical Question, can I wire a pair of 120v 15v or 220v outlets to a Intermati
    Post a picture with the cover off. What size breaker feeds the Intermatic from the main panel?
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
