Results 1 to 14 of 14
Thread: #8 copper bonding wire in equipment pad: is stranded ok?
    MitchRyan912's Avatar
    Jul 2015
    Madison, WI
    338
    Question #8 copper bonding wire in equipment pad: is stranded ok?
    I just realized I made an oversight and accidentally used stranded #8 copper wire instead of solid #8 to bond to the wire mesh in my concrete pad, a new pour last weekend. Is this a huge deal, or will it be OK so long as there is a #8 solid running to the pool frame, ladders, etc?
    2016 total pool rebuild thread: here. Pool: 26,000 gal IG vinyl liner (20'x40') in Madison, WI. Gear: ​Superflo VS, Triton TR-60 filter, 2" hi-flow MPV, & Raypak 266A heater. Testing: Taylor K-2006C. Manual chems: 12.5% NaClO liquid, granular CYA, baking soda, 31.25% muriatic acid.
    Re: #8 copper bonding wire in equipment pad: is stranded ok?
    Needs to be solid.
    Support the site
    Jul 2015
    Madison, WI
    338
    What happens if it's not? What's the likelihood an inspector would make an issue of that wire being stranded?
    Apr 2013
    Sacramento, CA
    2,769
    Most Inspectors would fail you.
    The code requires solid wire for several reasons. First sold wire has greater current carrying capacity as compared to the same size of stranded wire. Another way of saying that is that sold wire has less resistance than stranded wire. Why is that important? Well in a bonding system you want the bonding system to have as little resistance as possible so voltage is equal throughout the system. The standard calls for a #8 sold copper wire. That will have less resistance than a #8 stranded copper wire.
    More importantly stranded copper wires, especially uninsulated wire, are susceptible to corrosion from the inside out. Uh?
    In other words instead of having the outside of one copper wire corrode, we have many corroding because stranded wire has multiple times the surface area of solid wire. Corrosion further reduces the cross section of the wire and its ability to act as a low resistance bond connection.
    Jul 2015
    Madison, WI
    338
    Any chance I lucked out by using TWO #8 stranded wires? If it's about current carrying capacity, then a pair of #8 stranded wires will have more capacity than a single #8 solid.
    If not, how in the world can I fix this in 2 days without tearing up a brand new pad? PB will be here to set the gear on the pad on Monday!
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by MitchRyan912 View Post
    If you used stranded wire how did you attach it to the rebar? Plus, if you have already poured, how would add the second #8 stranded inside the concrete?
    I'm sorry to say (as Gordon pointed out) that most inspectors will fail the inspection. The code is specific to solid wire.
    Support the site
    Jul 2015
    Madison, WI
    338
    I put two #8 wires in before I poured, attaching them in two spots to the wire mesh (no rebar) with a pair of split bolt connectors. I sanded down the mesh to remove all the rust, to give it a better connection to the wire.
    Jul 2015
    Newton, NJ
    89
    Didn't you have to have the bonding inspection BEFORE the concrete was poured?
    20K gal, IG Fiberglass "Lifetime Pittsburgh", 1 1/2 HP TriStar pump, 525 sqft cartridge filter, AutoPlus T-15 SWG, Dolphin Oasis z5 Robot
    Apr 2013
    Sacramento, CA
    2,769
    So go invest in some more split bolts and where the two wires emerge from the slab connect solid #8.
    I'm not going to tell you that complies nor will I tell you that will pass an inspection. To comply you have to jack the slab.
    However I will say stranded encased in concrete will probably corrode less if exposed. You don't want bare stranded out exposed to the weather or buried in soil. Trippe no to buried in soil.
    Jul 2015
    Madison, WI
    338
    Quote Originally Posted by avc8130 View Post
    I built the pad myself, and didn't know that an inspection was needed. This project is considered a repair of an existing IG pool (built 40+ years ago). I'm not sure how that affects things, but had we used the old pad instead of putting the gear in this new location, then there would have been no bonding of ANY kind done on that old pad, much less any other part of the pool. The ladders were previously grounded with the ground conductor in a 12/2 romex, connected to the water spigot nearest to the pool. The steel wall frame of the pool was never bonded.
    Mar 2015
    Texas
    28
    My equipment pad (built last year) has rebar in it but there was no bonding to the pool or the equipment located on it. The equipment is bonded using solid copper wire to the pool and decking around it though. It passed inspection. (Houston, Texas)
    Pool newbie - In ground 13.5k gallon gunite pool & spa. All Jandy equipment - 2.0HP VS pump, iAqualink touch controller, Jxi heater, & AquaPure salt cell system, CL 580 cartridge filter, & 1.0HP water feature pump. SAVI LED lights.
    Jul 2015
    Madison, WI
    338
    Quote Originally Posted by gwegan View Post
    You can see in this picture of the concrete after pouring, the 60' length of wire sticking out of the side (corner closest to the bottom of the pic). That wire also comes out through the top of the concrete, so it exits the form in two spots.
    Might I be able to attach a solid #8 to that long length of stranded #8, and bury that connection in a small form of concrete to prevent it from being exposed to the elements? At that point, I'd just attach everything together from this new connection and cut off the wire sticking out of the concrete. Thoughts? Might I be any closer to passing, assuming there even is a bonding inspection on a rebuild project? (I question that there even will be a bonding inspection, as bonding never came up in talks with either the PB nor the PB's preferred electrician.)
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,812
    So to make you life easier and because you technically didn't need to bond the pad because it is so far away from the pool. Get your solid lie and use a connector to that stranded wire in the slab. Then run the solid up onto the pad to go to your pump and heater. Then run it out to your pool and you will be fine.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Jul 2015
    Madison, WI
    338
    Pretty sure that's the best news I've heard all day! I went to bed in a bit of a panic last night, as my wife wasn't really thrilled with doing a concrete pad (she wanted 2'x2' pavers), so I never would have heard the end of it if I had messed up something... on the electrical end of the pad build!
